sealing a lower intake bolt
Old Feb 10, 2009 | 11:42 PM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
The intake bolt that is holding my intake manifold to the driver side head, right behind the thermostat housing, is leaking some oil. I am assuming that it did not get sealed properly and oil vapor climbs up the threads. Can I just take that bolt out, put some RTV sealer on the threads and bolt it back down, or do I have to loosen all of the bolts and torque them down simultaneously? I have no leaks from the intake manifold gasket and all the other bolts are fine, but this one leaks, resulting in a small pool of oil on top of the intake manifold behind the thermostat housing. Access to the bolt is easy, I just want to make sure that no harm would be done by taking off only that one bolt.
Any suggestions would be greatly appreciated.
Thanks in advance.
Old Feb 11, 2009 | 04:46 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: sealing a lower intake bolt
You should be fine doing just the one bolt.
Remove it.
Clean it up really well.
Chase the threads in the head.
Put on teflon sealant.
Torque it back down.
Old Feb 11, 2009 | 07:18 AM
Saculia's Avatar
Engine: 305TPI
Remove it.
What is the teflon sealant? Would RTV not work?
1992 Trans Am
May 10, 2023 07:19 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
86White_T/A305
Aug 17, 2015 12:16 AM
knight72
Aug 10, 2015 09:32 PM
