Gas problem
Old Mar 6, 2009 | 05:48 PM
  #51
liljon285's Avatar
Car: 1987 IROC
Engine: 5.0 TPI all stock
Axle/Gears: G92 G80
Re: Gas problem
Fuel Pump installed and it runs great hasnt done the noise or the fuel cut thing again. But now after driven for a long time, it kinda smells like gas inside the car. Could this be the timing?
Old Mar 6, 2009 | 07:13 PM
  #52
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Gas problem
Not likely. Are you sure nothing is leaking? It could also be a bad check valve letting fumes out.
Old Mar 7, 2009 | 07:51 AM
  #53
liljon285's Avatar
Car: 1987 IROC
Axle/Gears: G92 G80
Re: Gas problem
A bad check valve? Well no nothing is leaking, its only after a certain period of time driving. Where is the check valve located.
Old Mar 7, 2009 | 10:16 AM
  #54
jv9999's Avatar
Engine: 5.7L/350
Re: Gas problem
The check valve is attached to the rear axle on the drivers side with a hose running to the tank. They fail pretty often and are still available from GM.
Old Mar 7, 2009 | 11:07 AM
  #55
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: Gas problem
This the golf ball looking thing with the rubber hose from the gas tank?
Old Mar 7, 2009 | 10:27 PM
  #56
liljon285's Avatar
Car: 1987 IROC
Axle/Gears: G92 G80
Re: Gas problem
Thats the Vent Valve...it was already spoken of here...thats not the problem. Well it COULD be the gas smell but i dunno i doubt it. But today the car turned off on me. Its still running weird....i HATE not being able to trust my daily! =[
Old Mar 8, 2009 | 07:34 PM
  #57
liljon285's Avatar
Car: 1987 IROC
Axle/Gears: G92 G80
Re: Gas problem
Ok so i checked the fuel pump again, seems the o ring was the big one it brought not the small one and it needs the small one...so i replaced it with the small one and i think it solved the shutting off and gas smell problem. But Istill feel the car running a bit off. The idle is rough, and sometimes it revs decently high and then sometimes kinda low so it has me worried...im having a big beach group thing on wednesday and im scared to drive the car to the beach! lol Could it be just a tune up. The spark plugs are new, not sure about the wires. I hear a small knock inside the engine too i think cuz of a big oil leak it has(but the oil is still good amount wise) im gonna give it an oil change and some new wires and then when i can afford a cap and rotor ill go ahead and install those...sounds good? Meaning you think that will get rid of my weird rough idle and different idles lol?
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
db057
Sep 4, 2015 07:57 AM
92camaroJoe
Aug 13, 2015 06:07 AM
