Why wont my engine run?
Old Feb 16, 2009 | 04:25 PM
88_firebird_TPI's Avatar
Hey, i recently bought an 88 firebird formula TPI. When i bought it, it ran alright, so i replaced the spark plugs, fuel filter, distributor cap, and rotor. After that it ran great for a couple weeks. then it started to die out and idle really rough, so i replaced the vacuum lines but that didnt solve the problem. the problem eventually got worse, and now the car will only start for a couple seconds then it will die out. It will not take any fuel, unless i sit there and pulsate the pedal, but t will run very rough when i do that, and it will backfire out of the intake a lot. after that i replaced the fuel pump, and it does pump fuel, and i am really sure there is enough fuel at the engine.
Im completely lost on this one, but someone told me it could be the lobes worn down on the cam
Please help
Old Feb 17, 2009 | 05:02 PM
Re: Why wont my engine run?
Also, would the car run for a couple seconds like it does if the fuel injectors arent working?
Old Feb 17, 2009 | 05:07 PM
jshepit's Avatar
Car: 1988 IROC
Transmission: BW 5-Speed
Axle/Gears: 3:73
Is the engine service light on? If so, pull the codes and see what they say.
Old Feb 19, 2009 | 12:02 PM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
Since you have addressed the fuel pump and filters, and replaced your spark plugs, you may want to check the ignition coil.
First, I would pull the spark plugs. How they look (refer to your Haynes, Clymer, Chiltons etc) may give you a clue as to what's happening.
If they are black and sooty, your ignition coil could be the problem. If not, their appearance could give you clues as to what's wrong.
Old Feb 19, 2009 | 10:05 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
How are you sure there is enough fuel? Did you measure the fuel pressure? Still sounds like a FP problem to me.
Old Feb 20, 2009 | 09:37 AM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
It does to me, too, but he does say that he has changed the pump and filter. Unless there is another filter that he missed or some other type of blockage, I can see why he assumes that. Of course, there is no substitute for measuring pressure at the fuel rail.
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
camaroken83
Aug 10, 2015 11:35 AM
