How many have gone back and re-installed your EGR equipment?
Old Feb 19, 2009 | 03:49 PM
Erik formula L98's Avatar
I've been getting excessive exhaust fumes around and inside my car and I've been thinking of adding back my smog equipment. How many of you have done it and have you noticed a difference?
Old Feb 19, 2009 | 09:28 PM
curacaoz28's Avatar
Car: 1985 Iroc-z28(sold) 1994 camaro z28
Engine: 350lt1
Transmission: 6-speed manual
Axle/Gears: ???
Re: How many have gone back and re-installed your EGR equipment?
didnt do it yet but I'm about to do it!
Old Feb 19, 2009 | 10:00 PM
Are you doing it for the same reason?
Old Feb 19, 2009 | 10:02 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
I believe the EGR does more good than harm, but it's probably not your problem (it's inactive at idle for one thing). I suspect you have a mixture issue.
Old Feb 20, 2009 | 12:10 AM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
You could have an exhaust leak somewhere towards the front of the car.
Old Feb 20, 2009 | 01:37 AM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
im putting my 91 trans am back together(bought as basket case lol)
im installing
--egr parts
--air pump/lines(this maybe a tad hard)
--SINGLE 3" cat(dual cat setup is stupid expensive)
so im going the opposite way of a lot of 3rd gen owners
atleast my car will be legal and smell good
Old Feb 20, 2009 | 06:29 AM
riceca's Avatar
Car: 1997 Tahoe
I am deleting all that mess on my TPI build... But that is just me.
Old Feb 20, 2009 | 09:44 AM
I also thought it was a fuel mixture problem but I have my f/p set at 48 psi. and every time I check my plugs they are a light reddish which is considered normal right? You'd think if I was running rich the plugs would be black. Maybe my chip is running too rich at idle?
Old Feb 20, 2009 | 12:19 PM
jv9999's Avatar
Engine: 5.7L/350
It may be running rich in open look when it's idling. How old is your O2 sensor?
Old Feb 20, 2009 | 12:25 PM
IROCmatt's Avatar
Car: IROC Z28
Engine: 5 litre 305
ive started taking all the egr stuff off mine, as it does not need it
Old Feb 20, 2009 | 12:44 PM
Probably too old. The last time I replaced it was back in '02 and the car has sat in my garage since then and hasn't racked up more than a couple thousand miles. I take it out for a spin maybe once or twice a month.
Old Feb 20, 2009 | 01:35 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
I know when I installed my hedmans the first time around, even though it cleared the A/C heater box, it used to heat it up something aweful. The smell persisted until I removed the box. Something about that fiberglass getting all hot, it stunk. Just a thought
Will
Vintageracer
Jan 10, 2020 05:33 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
drathaar907
Aug 6, 2015 04:20 PM
