91 L98 wont start(dead computer?)
Old Feb 27, 2009 | 02:42 AM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
Hi all, for the past 3 hours ive tried searching and to no avail i didnty find an answer.
Last year the car ran with P.O., i get it and buy all the correct things for the 90-92 specific Speed Density setup. (p.O. pulled built motor/trans/ECM for his s10 swap...but left me a non hacked harness)
I go to fire up the project up last night and noticed no drop in fuel rail PSI(pull pump fuse and crank over). So my thought is computer isnt firing the injectors. After a few tests, i know im getting spark to each plug so thats not it.....
When i turn key on i dont get a SES or CEL light at all. No blinking no steady light...where do i start testing?
When keys is turned on i get this light sequence
1.air bag light(blink few times and goes off)
2. sercruity light(vats?) comes on for a second and then goes off....
So im getting spark...motor rolls over...no smell of fuel and no SES/CEL light
im hoping someone has a clue why im tearing hair out of my head
BTW....new fuses EVERYWHERE
Old Feb 27, 2009 | 11:57 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
Re: 91 L98 wont start(dead computer?)
no one?
im thinking the computer is dead im out big $$$$
guess when you buy parts and comes to you in poor shape your sol
bought ECM and it says reman from ACDELCO 1995
member here said the car ran and everything........im hoping testing it in 3rd different car(friens if he lets me) proves me wrong
Old Feb 28, 2009 | 07:12 AM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
try this. on a 91 computer if there is a shorted injector it will not operate. unplug each injector and with a ohm meter check the injectors they should read 14 to 16 ohms. under 10 is ng. this is only a good test if the factory multecs are still in the engine. i am assuming they are. if you find a bad 1 or 2 keep them unplugged and try to start. if you need injectors call Jon at fuel injector connection.
good luck
Old Feb 28, 2009 | 08:28 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
no one?
Is the fuel pump coming on?
don't you have an lt1 intake on an old school 327?
Thats what I remember from a previous thread of yours.
If everything swapped fine,it might possibly be the ecm.
If you know someone with a speed density car,a swap of ecms might give you your answer.
Keep us posted man!
BTW, got that surface rust fixed on the roof yet?
Old Feb 28, 2009 | 08:36 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
Keep us posted man!
i have not done the lt1 intake swap yet...TRYING to get a baseline of car b4 mods....
yes the fuel pump is "priming" or cycling
weird thing is the SES light is working now and im getting only code 12(i know what it is though)
car keeps wanting to pop though intake even though ive set the dizzy in 5 times at number 1 cylinder TOP DEAD CENTER
ive got 43psi of rail pressure but wont drop when cranking (like inkectors are not working)
i ohm'd the lt1 24# injectors out and they all came to 12.1 to 12.3
im about to light this piece of ***** on fire and roast marshmellows on it. Ive spent a ton of money trying to get this tpi crap to run and its not working. I dont want to hack the car and go carb but it looks like i might have to.
BTW...no the roof hasnt been touched...too busy figuring this junk out
TIMMY....just be glad you didnt buy this ecm....it came wityh tar and goo on it
Old Feb 28, 2009 | 09:17 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
how can i tell if VATS is killing the injectors?
i ohm'd the key and then ohm the connector at end of coluum and get same reading so i think vats is ok
IM LOST
Old Feb 28, 2009 | 09:20 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
IM LOST
just for the hell of it is the computer out of a 91 corvette?
Old Feb 28, 2009 | 09:21 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
nope a 730 ecm from a 91 camaro
Old Feb 28, 2009 | 09:30 PM
spanners's Avatar
is there power at the injectors unplug one and probe the plug one pin should have 12 volts when the key is on the other one gets earthed by the ecu to fire the injector
Old Feb 28, 2009 | 09:32 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
ill try to see ifthere is 12volts to the connector
Old Feb 28, 2009 | 09:37 PM
spanners's Avatar
sweet ill stay logged in till you have
Old Feb 28, 2009 | 10:45 PM
evilstuie's Avatar
Car: 1985 Pontiac TransAM
Engine: 400SBC 24x conversion
Transmission: T700r Stage2 Shiftkitted
Axle/Gears: 2.77 9 Bolt
if you look at it from another point of view..... a 91 car with a ecu reco'd in 1995 points to maybe something thats causing the ecu to short or blow capacitors.
but who knows.
can u get another ecu to test out?
I thought these ecu's had a backup mode that would run on a closed loop or something if it died?
Old Feb 28, 2009 | 10:48 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
okay...im almost 100% sure the computer is dead
--12 volts are at connector for injectors
--apply 12 volts to injectors and they click and fuel rail pressure drops finally
--has great spark
--43.5 psi of fuel pressure
--the SES light comes on when it feels like it wants to....
when the ses light comes on the car ACTS like it might fire up
im lost and about ready to dump gas on the car and burn it.....ive spent a lot on this car buying correct parts and such to get it running
Old Feb 28, 2009 | 10:50 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
but who knows.
to my understanding the car SHOULD run in limp mode if ecu dies......
but no...out of all my local 3rd gen buddies that are still TpI they are MAF
all the ecu grounds and 12+ are good........looks like i got screwed over buying a junk ecu
Old Mar 1, 2009 | 05:04 AM
hey toyata,does the memcal mount to an adapter board inside the ecm?
Possibly someone had the vats disabled in the ecm before you got it.
That keep you from getting the desired 12v to the inj.
Old Mar 1, 2009 | 07:42 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
The SES light should come on EVERY time, if it isn't, you only have intermittent power to the ECM, or the ECM is possibly bad.
The next thing I suspect is that the VATS may be screwing with you, but I haven't done tons of reading on that. If you get a chip and an adapter from www.moates.net, I'll come over and we can disable the VATS in the chip and try that. We can also then mess around with fan temps and whatever else you want changed.
Hey I'm a local thirdgen guy in the area and I have a SD '91 Trans Am, I feel left out! I'm mounting and balancing the tires for it today, and I'm going to tie up the loose ends and start driving the week of the 6th. Don't set your car on fire yet. Once mine is done I'll come up and help out. Do you have any wiring diagrams or trouble shooting flow diagrams for the car?
Old Mar 1, 2009 | 02:13 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
i need all the help i can get......i have a cable for aldl to USB for our 3rd gen and datamaster for 90-92...just my laptop is dead now(blue screen of death)
i have a chilton wiring diagram for wiring...but it sucks and i wish i could find better.
1MeanZ...i tried locating that black box and no avail....no fuses thing inline on the positive cable coming from the drivers side of car.
UPDATE for people that dont read though previous posts...ill give you the jist of the issue
--great spark
--43.5 psi of rail psi
--12 volts are present to the injector
--apply 12 volts to the injector and they release pressure
--SES light comes on rarely...(MAIN problem IMHO)
--INJECTORS ARE NOT GETTING A SIGNAL TO FIRE
Old Mar 1, 2009 | 02:17 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
ill have to take a pic of the chip when you take the door off the ecu........looks stock to me.....nothing like the adapters from the moats.net site
i think someone told me a bullshite story about the computer being modded for 24# injectors and stuff.....
Old Mar 1, 2009 | 06:11 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Don't worry about your tune, injector size, etc. If you have a good ECM, chip, and adapter, I'll help you burn a tune that will suit your needs.
I just got my rims and tires mounted and balanced today. I'll swing by Dad's tomorrow night and drop them off and see if I can find the ECM fuse on my Trans Am, then I'll report back on what I find.
Keep the faith!! You'll get it! YOu'll be glad you went TPI this summer when the car starts good and you're getting 20+mpg.
Old Mar 1, 2009 | 07:32 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
holy crap...the (*&*&&^$& thing fired up!
turns out buddy/neighbor put dizzy in 180* out and i didnt question his setup due to hes a engine builder LOL. i never did a check due to being alone i couldnt bump it over and check if piston was up
But big issue was ecm wasnt getting 12 volts.....even though every fuse and link and such was getting good 12 volts.....
so i put 12 volts to the ecm and BAM SES light came on...cranked it and the sweet sound of a 333ci tpi open header monster rang aloud!
so now im rigging a kill/run switch to put power to the ecm....the IAC is bad and motor is running at 1900rpm idle......the motor is VERY snappy. Im stupid happy and not long til this thing is driving. I have to figure out how to bypass the Hot H2o valve and TB for heater core.
Finding center bolt cover bolts locally is a pita......another thing holding this buildup back
Old Mar 1, 2009 | 07:41 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
great news, we knew you'd get it. keep being meticulous and get all the issues fixed, including the IAC motor and such. You can't properly tune the engine unless everything is working like it should.
Old Mar 1, 2009 | 07:50 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
im trying to search and find how to test the IAC and wires to IAC....
Old Mar 1, 2009 | 09:00 PM
cool toyota! Glad to hear shes alive!
on the IAC thing.
when I swapped my 305 tpi to the alum. head vette tpi I kept the stock 305 memcal and purchased 22lb. inj. from fic.
You know I was looking for a 350 memcal just like you!LOL
I found a local buddy that programmed my 305 memcal to run correctly with my 350 and even was able to reset some of the settings in the IAC.
He got the black bird running great!
Old Mar 3, 2009 | 02:12 AM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
maybe someone can point me in right direction...i need to test my IAC motor to see if its good...i dont want to buy one for 80 something dollars and turn out to be ecm issue.
But timmy...The ecm and memcal is for a L98 and thats basically what im running
thats the chip...looks weird...but nothing like the MOATS.NET adpaters?
Old Mar 3, 2009 | 02:58 AM
bbpping's Avatar
the adapter goes to that spot and the memcal will plug into the adapter, that's one way to do it anyways..
what's a "dizzy"?
my 91 RS with the TPI swap won't start either... have fuel pressure and good spark, injectors just aren't firing
Old Mar 3, 2009 | 07:42 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Shelby, that is just a factory computer chip. The moates adapter allows you to run that chip (called a memcal) and also add a chip that you custom burn. Go to www.moates.net and look for chip adapters and you'll find them. I think they are $40 or something. If you need more help with it, let me know, I'll send you the exact link of what you'll need to buy. Get the car running and all the bugs worked out, then if you want to make changes, just buy the adapter and a few chips and I'll come mess with the tune. We can easily disable the VATS, lower the fan temps, change idle speed, etc.
Old Mar 3, 2009 | 07:38 PM
1meanz,I don't think hes going to need the vats disabled now since the car is running.lol
toyota,I have 3 sets of factory centerbolt valve covers here,pm me if you want a set.
You can have them for $15 shipped.
Old Mar 3, 2009 | 08:09 PM
evilstuie's Avatar
what's a "dizzy"?
LOL
dizzy=distributor :P
Old Mar 4, 2009 | 12:21 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
what's a "dizzy"?
okay...heres a check list a friend gave me and i ended up finding out my ecu wasnt getting 12 volts...your maybe something esle:
--Check engine light coming on at all?
--Sercuity light coming on and then goes away?
--12 volts to the injectors with key on?
--apply 12 volts to the injectors one by one with fuel rail pressurized and listen to hear if they "bleed off"(just do one with pressure in rail or you will hydro lock your motor.....and thats not good lol)
--try applying 12 volts to the injectors quickly...like a tap tap tap...listen for clicking
Old Mar 4, 2009 | 12:31 PM
bbpping's Avatar
thanks for the reply!
I haven't looked at it for a while now, but will check those as soon as I get back from my Vacation haha.
So do I have it right that the ECU grounds the injectors, so there should be a constant +12 at the injector with the key on?
I've tested the injector plugs while cranking with a noid light, nothing shows up. So the injectors are definitely not getting a signal.
Old Mar 4, 2009 | 12:49 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
to my understanding thats how the injectors are fired...so yes there is 12 volts to one wire and the ecu controls the other.
Old Mar 4, 2009 | 05:22 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Heh, he will this summer when his car won't start in the mall parking lot because his VATS module crapped out on him and the car is stranded because of a stupid key.
Old Mar 4, 2009 | 05:54 PM
haha!!So true!!
Thanks for that one 1meanz!I needed a good laugh today.
So toyota,you want a set of free valve covers?Just send me $15 to cover the cost of shipping.
Heck,I'll even throw in a vats module!LOL!!
Old Mar 4, 2009 | 11:47 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
haha!!So true!!
are they the grey ones? if so then sometime this weekend ill send you paypal
but yah im gonna have vats taken out....more i think about it...i dont want it leaving me somewhere. Most likely will be taking GF out to movie or MALL LOL and car wont crank
Old Mar 5, 2009 | 10:39 AM
Pocket's Avatar
Car: 91 Trans Am
No need for a kill switch, C207 pin F is the ECM to fuse box 12v
IAC likely needs a cleaning, refer to the tech articles on the main page on how to do this right and not damage the IAC
wiring looks like this:
http://www.austinthirdgen.org/mkport...ta_sensors.jpg
For the heater diverter valve, read this:
https://www.thirdgen.org/forums/tbi/...up-your-3.html
Its the same as TBI except the intake line is in the front near the water pump, not the rear, so you will always have a line going over the intake until you do the LT1 intake swap
http://www.austinthirdgen.org/index.php?pid=5
Another bit is how you can cut the coolant barbs off the TB with no consequence
what's a "dizzy"?
Injector circuit
http://www.austinthirdgen.org/mkport...ontents/images
/diagram_1992_tuned_port_injection_V8_vinF_and_vin8_fuel_injectors.jpg
http://www.austinthirdgen.org/mkport..._injectors.jpg
You can see they all use the same pins on the C207, only the number of injectors and ECM pin assignments change
Depending whether your RS was TBI or V6 your VSS assignment will change
TBI has the VSS going thru the C100 bulkhead connector, V6/TPI goes strait to the ECM
V6 will have no change, TBI you will have to bypass the buffer box or your Speedo/cruise will not work
There are numerous VATS disable articles on this site and others
Old Mar 5, 2009 | 05:02 PM
Yeah man,they are the grey TPI covers.
If you want pics,pm me your email and I can get some this weekend.
I have a bunch of parts kicking around here so,if ya need anything else,
just ask.
Old Mar 7, 2009 | 11:24 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
okay....im so confused im cross-eyed and drooling ....lol
car fired up with everything hooked up and fluids topped off......idle finally came down
then as it was coming up to temp(running amazing mind you)...it shut off
wait a few minutes and it refires and runs for 15-30 seconds and dies again....while it refires its running extremely rich(burns yours eyes out)
NOW it wont re fire....so im thinking either coil is bad or IGN module
The car is running VERY good oil pressure...has fuel pressure...SES light is still on....i have to check for spark tomorrow.
Old Mar 8, 2009 | 11:06 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
http://www.youtube.com/watch?v=JgmxKmfqILc
its running now :shrug:
vid doesnt do it justice lol...found out ign module and tps were dead...car runs excellent now
lol at teh choppy 900rpm idle.....i think the oxygen sensor is dead...hence stupid rich rev
Old Mar 25, 2009 | 09:41 AM
GM4e's Avatar
Any ideas why ive got 12v on BOTH injector wires with key on?
Old Mar 25, 2009 | 11:22 AM
92 Z-28 Camaro's Avatar
Car: 1992 Z-28
Transmission: auto
Hi Folks
this may sound dumb but check your battery - I have a 87 TPI that sits for a long time, when I go to start it does the same thing, dies, restart, after a couple of tries, it runs. I have noticed once the voltage is above 12 v it run ok, below 12 it will not run long. I replaced the battery it run a lot better after sitting for a while.
thanks
Bill
Old Mar 25, 2009 | 11:42 AM
GM4e's Avatar
Originally Posted by 92 Z-28 Camaro
Hi Folks
thanks
Bill
Yeah I keep a battery charger on it when im going to be working on it for any amount of time, thanks for the input.
BTW, could a bad injector cause a closed circuit, sending 12v to the signal wires from the PCM (blu/grn wires)
Old Mar 25, 2009 | 12:52 PM
  #42
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
its supposed to have 12 volts constant at the pink/black wire fir injectors...thats how they work.
the computer fires the injector by the blue or green(color respective to each side)completing the circuit
Old Mar 27, 2009 | 08:28 PM
  #43
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
well...it revs really good but wont drive worth a crap
misses.......pops....spits....will not accelerate at all!
but while coasting or just pressing gas enough to keep at same speed you blip the gas and sounds like a race car and you think its gonna race off.....wrong. it acts like its out of time or something but everything is new and timing is dead on at 6*BTDC with est disconnected.
i did see that i have the MAP line hooked up to the wrong port on the plenum. I have the map line hooked to the LARGE port out of the 3.
What would it do if the map line is too long and too large? I thought it would have better throttle response. When doing a free rev it, it revs right up to redline....but like stated before when in gear it runs like crap
someone help
Old Mar 28, 2009 | 09:24 AM
  #44
Pocket's Avatar
Car: 91 Trans Am
MAP doesnt care where it gets vacuum, only that it gets some ()
Check for other vacuum leaks
Did you ohm the injectors?
How old is the fuel filter
Old Mar 28, 2009 | 06:37 PM
  #45
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
welp....my cars done for a few weeks
fuel pump took a dump today while out driving.....tried to put new fuse in the fuel pump fuse holder under hood and blows it instantly....motor shorted out.
i was running 23psi.....then i adjusted the regulator back up to stock psi level and car ran a lot better......then pump died out...
im not looking forward to changing a fuel pump out
Old Mar 30, 2009 | 04:58 PM
  #46
Car: 1992 Z-28
Transmission: auto
Hi
The fuel pump isn't to bad, just drain the tank before you try lowing it. I had to disconnect the rear end and move it forward. Once you do that, why don't you put back the stock tuning because your engine is pretty much stock anyway. Get it to run with the stock tuning than go for the enhanced tuning.
thanks
Bill
Old Apr 1, 2009 | 12:23 AM
  #47
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
Hi
thanks
Bill
well after talking to a lot of people i dropped tank correctly and swapped pumps.....
only to put new fuse in and it blows! turned out this whole time a wire had melted to the header that came from the oil pressure sending unit this in turn shorted the circuit out for the fuel pump. I was so pissed when i found that wire melted........and to add to my mental stress....i pulled a brand new WALBRO 255lph pump out.
SO! car runs and drives again...LOL
I did find out autozone radiator caps dont work at all....car came to temp and coolant started flowing out around the cap. I took cap off and bent the tabs that hold it on the neck and it holds pressure now.
CLIFFS: now i know why people cut their cars up to change fuel pumps....pulling it right way is retarded
Old Sep 3, 2010 | 06:06 PM
  #48
JO-MARO's Avatar
Car: 91 RS
Engine: tbi 305 v8
Transmission: swaped for v6 m5 lol lots-o-torque
Axle/Gears: stock :(
check and see if its been chopped first cause it saves alot of time and there is nothing that made me more pissed doin this in my drive way more than after gettin out the tank and seeing it cut open .....lol.......not funny
Old Sep 5, 2010 | 11:27 AM
  #49
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Never mind
I just read the rest of the thread
DOH!
Last edited by John 89 Formula; Sep 5, 2010 at 11:30 AM. Reason: my suggestion already posted
Old Sep 5, 2010 | 01:30 PM
  #50
JO-MARO's Avatar
Car: 91 RS
Engine: tbi 305 v8
ya the fuse was blown but i still drove it my friend helped me run power to the fuel pump and after it turned over for a bit it would fire up but now im tryin to reverse the damn thing i got the fuse in now and CES/SES light comes on but i swaped injectors to see if they were bad but i guess they were good so now im waitin for gaskets to come and should have it worked out soon !!!!! hope so cause i just moved and i really need it to start so it can get outa there
Orr89RocZ
Apr 25, 2016 08:28 AM
TheExaminer
Aug 19, 2015 10:07 PM
Bryan F
Aug 18, 2015 02:28 PM
matthew911
Aug 12, 2015 09:38 AM
Bradsaundry
Aug 12, 2015 12:34 AM
