Estimate of HP?
Old Mar 1, 2009 | 06:48 AM
Kodfish's Avatar
Car: 1990 IROC
Engine: 5.7 TPI
Estimate of HP?
Hey folks, have a question? I purcahsed the 200cc Dart heads from TPIS, Mini ram intake, and zz9 roller cam. I'm planning on rebuilding the bottom end also, still hoping to keep it a 350. I read about 58cc or 52cc and think it would be best to go with a 52cc thottle body. Also going with Comp cams full roller rockers. How much HP and Torque do you guys estimate I can get out of my new engine? Its a speed density system. Guys at TPIS estimated around 400-420, what do you think? First engine rebuild and would like to get 400. Any info would greatly be appreciated.
Old Mar 1, 2009 | 11:53 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: Estimate of HP?
I had that same combo a few years back. It made around 300 horse at the wheels and around 330 torque. You should go with the zz409 cam. Its like night and day with performance. It added 30 more horse and 28 with torque
Old Mar 1, 2009 | 01:13 PM
Kodfish's Avatar
Car: 1990 IROC
Engine: 5.7 TPI
Re: Estimate of HP?
Just curious what HP you are putting out with your setup now, it looks similar to the setup I have in mind. I would like to get 400, what else could i do to acheive that level
Old Mar 1, 2009 | 02:04 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Re: Estimate of HP?
with my 383 setup i am making 470 horse with 455 lb torque
Old Mar 5, 2009 | 07:26 AM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: Estimate of HP?
cant believe u guys will only be pulling 400-420hp wiht the dart 200cc heads and mini ram... what are u guys lacking on?
like joeblue83, my 383 will be pumping out about 480-490hp and 480-500ftlbs. with 195cc patriot heads and a comp cams XFI 280. and a HSR.
u should be able to squeeze more power outa those heads/intake. easily
Old Mar 6, 2009 | 12:47 AM
ModPog84z28's Avatar
Car: 1989 Camaro RS
Engine: 496 BBC
Transmission: T-56 6 speed
Axle/Gears: 4.11 posi
Re: Estimate of HP?
your talking 383 vs 350. joeblue83 said he wants to keep it 350 cubes. i think 400-420 is pretty respectable with a miniram and 200 cc heads. yea if he dropped a bigger cam and tweaked it i could see around 450-470 hp and 420 tq. but a 383 is definitely gonna be able to do more with the slightly smaller heads.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
skip91
Sep 24, 2015 03:29 PM
ULTM8Z
Sep 16, 2015 09:15 AM
bellez77
Sep 5, 2015 08:39 PM
Trevor K
Jul 12, 2001 01:44 PM
