oil pressure sending unit/ gauge
Old Mar 13, 2009 | 03:53 PM
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
I bought a mechanical oil pressure gauge and to get it to work i have to connect it in the hole where the oil pressure sending unit goes. do i need to have the sensor in order for the car to run and if so how do i connect both of them in to the same hole. is there a splitter that i can put there so both can be connected or do i have to make a new hole.
thanks
steve
Old Mar 13, 2009 | 10:17 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: oil pressure sending unit/ gauge
the easiest way to get both of them on there is using a "tee/T" splitter with 1/8th NPT ports on it. I believe the oil pressure ports on our engines are 1/8th NPT. Connect the T to the hole and the oil pressure sensor on one end and the oil pressure gauge to the other....
Old Mar 13, 2009 | 10:24 PM
chris.niemann84's Avatar
Car: 1985 IROC Z28
Engine: L98 - 350/650 Holley DP
Axle/Gears: 3:83 Full Spooled
there should also be a square headed plug under your distributor behind your intake up against the firewall that you can take out too. I believe it requires an 8mm wrench on it. Need to pull the distributor to get to it though, then you don't have to worry about any leaks or a mis-read on your pressure from your gauge or your sensor. If you can't find it, i'm sure I can get pictures somewhere....
Old Mar 14, 2009 | 11:42 AM
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
where might i be able to buy that splitter and can i see some of those pic
Old Mar 14, 2009 | 12:55 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
i've seen the splitters at home depot, i actually had to buy a coupler when i did my hsr swap, they should be with the tubing area and are a few bucks
Old Mar 14, 2009 | 01:26 PM
Car: 1985 IROC Z28
attached are the pictures of the small plug on the back side of the block. i used the great wonderful MS Paint to help with the identification process... hope this helps out some.
Attached Thumbnails oil pressure sending unit/ gauge-100_8577_1.jpg   oil pressure sending unit/ gauge-100_8578_1.jpg
Old Mar 14, 2009 | 02:35 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
I just did this to my truck(GMC K1500, 5.7L) not too long ago because the original oil gauge started reading low pressure and I wanted to see if it was a bad gauge or sender. My OEM sender is in the location behind the distributor pointed out by chris. I had to use a 90-degree elbow fitting then to the Tee fitting to clear the distributor and firewall. Both gauges read exactly the same and I have haven't had any problems with it. I used 1/4" NPT I believe brass fittings and got them in the plumbing section of the local Home Depot. Cost me all of $5 I think.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
