upgrade 350 tpi
Old Mar 14, 2009 | 08:37 PM
cmtison's Avatar
Car: 1992 B4C
Engine: L98 soon to be 383
upgrade 350 tpi
im putting on:
Stealth Ram EFI Vortec Intake Manifold 1955-86 262-400ci w/1996 & later Vortec (L31) heads
Idle-6500 RPM Range
SB Chevrolet Vortec Cylinder Head w/ 0.600 Springs for Roller Cams
XFI" 268 Hydraulic Roller CamshaftChevy 262-400ci 1955-98
Lift: .570"/.565" w/1.6 Rockers
Duration: 268°/276°
RPM Range: 1800-5800
and i need a new/used good Throttle body to replace the stock one. and fit those parts i listed. any suggestions?
Old Mar 15, 2009 | 09:43 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: upgrade 350 tpi
I'd go with a 52mm throttle body. Any aftermarket one is good, just make sure it has a built-in air foil.
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
