Intake Manifold
Old Mar 16, 2009 | 03:59 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Intake Manifold
Quick question, are all the intakes for TPI engines the same? I mean 305, 350's, and Corvette intakes?
Old Mar 17, 2009 | 07:59 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Intake Manifold
The 85-86 f-body intakes are the same, as the engines are all 305's. The 87-92 f-body intakes are all the same for both 305's and 350's. The difference is in the intake bolt angle on the newer years.
The Corvette TPI intakes all have the 86 and older bolt pattern, plus they have the hookup on the back passenger side for the EGR supply.
Old Mar 17, 2009 | 08:04 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Re: Intake Manifold
So I would be able to use a 87 tpi intake on a 89 corvette tpi engine?
Old Mar 17, 2009 | 08:15 PM
Kevin91Z's Avatar
Re: Intake Manifold
With the '89 Corvette heads? No, because the center four intake bolt holes will not line up. (you could grind them to fit) but the f-body intake does not have the EGR port and you wont pass CA's emissions without it.
This is what you need to do for Corvette heads and EGR:
https://www.thirdgen.org/forums/tpi/...emissions.html
See my post in that thread with the pictures.
Old Mar 17, 2009 | 09:22 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Re: Intake Manifold
So what do I do to pass smog with the corvette intake?
Old Mar 20, 2009 | 02:47 AM
Kevin91Z's Avatar
Re: Intake Manifold
Hook up the exhaust tube going from the exhaust manifolds/headers to the port on the back of the intake manifold, as shown in the pics.
Old Mar 20, 2009 | 05:00 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Re: Intake Manifold
Alright thanks.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Blue419
Sep 10, 2015 01:03 PM
BOOT77
Sep 5, 2015 03:55 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
