Primary Fan Setting When Burning PROM Chip
Old Mar 17, 2009 | 05:55 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
Transmission: T-5 WC
Axle/Gears: Yukon 3.73
What have people had their primary fan set to when altering the PROM chip? I am about to have a PROM chip burnt. I have a 160F high flow thermostat. I live in place where summer temperature is typically in the high 20C to mid 30C. I am thinking of installing a Hypertech secondary fan switch, which turns the secondary fan on at 176F and turns it off at 166F. Therefore, I was thinking the primary fan should be set to coincide roughly with the secondary fan setting or maybe a bit cooler so that it comes on just before or at the same time as the secondary fan.
Old Mar 17, 2009 | 07:19 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Primary Fan Setting When Burning PROM Chip
With a 160 thermostat, I set the primary fan to come on around 85* C, and off at 83* C. That's around 180-185* F.
Old Mar 18, 2009 | 04:38 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Mine's set to 10 degrees above my stat temp.
Glowsock
Jul 24, 2025 03:15 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Sanjay
Aug 12, 2015 03:41 PM
Exxon Limited
Aug 9, 2015 08:13 PM
