350 squeaking
Old Mar 18, 2009 | 08:14 PM
yamban's Avatar
Car: 1985 Z28
350 squeaking
Hello! I recently bought myself a 1987 camaro IROC-Z with the L98 350tpi. I have 2 kinda of squeaking.
1) I start the car up, some sort of squeaking from the engine bay occurs but quickly goes away. Then, whenever I rev it the squeaking is back. Also happens when acceleration.
2) When turning the steering wheel to a certain point left or right I get this awful squealing noise
Also, when my camaros at idle, it's around 500-700 rpm and sounds like it's about to stall on me...but never has.
Thanks alot everyone! I'm relatively new to the camaro scene. Well, to the automotive seen as this is my first vehicle
Old Mar 18, 2009 | 08:29 PM
Gramps's Avatar
Car: 87 Camaro IROC
Re: 350 squeaking
well the squeak is the alternator belt, get that thing tightened by loosening the 2 alternator bolts, get a long bar and pry on the alternator to tighten the belt, before letting go of the bar, tighten the 2 bolts and you should be saved.
and for this steering thing i would suggest the same thing, your belt is just loose. unless this squeak is only happening when your at the end of steering travel left and right.
Old Mar 18, 2009 | 09:27 PM
bgood71's Avatar
Car: 89 GTA
Engine: 350tpi,HSR, underdrive pulley,tbfb
Axle/Gears: 3.27 Posi
Re: 350 squeaking
Sounds like belts that need tightened or replaced. The P/S belt on a multi belt setup can be tricky.
Old Mar 19, 2009 | 10:59 AM
yamban's Avatar
Car: 1985 Z28
Re: 350 squeaking
Ok cool thanks alot...I'vee try tightening it later on today. As for the steering squeak, it only happens when you are at the end of steering travel...this isn't bad is it?
Old Mar 19, 2009 | 11:29 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Re: 350 squeaking
could be the power steering pump going bad
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
