Computer Problem
Old Mar 21, 2009 | 11:30 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Computer Problem
Idk if I'm posting this in the right place. My mechanic just finished my swap from a 87 305 TPI to a 89 Corvette TPI. I used the wire harness from the 87 and when I hooked up the 89 computer from the Vette the car wouldn't start. It cranked but didn't start. I changed the computer to the 87 and it started up, and my service engine light came on.
Why did it start with the 87 computer?
Any help is greatly appreciated.
Old Mar 21, 2009 | 11:45 PM
rezinn's Avatar
Re: Computer Problem
VATS?
Old Mar 22, 2009 | 12:32 AM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
I'm new to a lot of things. Can you tell me what that is?
Old Mar 22, 2009 | 09:04 AM
tinymay's Avatar
Engine: 5.7 TPI
Vehicle Anti Theft System (VATS) - Engine usually turns over but but the injectors are disabled, I think. If that is the problem, you're gonna have to do some homework. Like getting the proper size resistor and soldering it into your harness OR get one of those black box simulators they sell on eBay. There be some other work arounds but that's what it sounds like you need.
Just my guess...
Old Mar 22, 2009 | 10:02 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
hey tiny how goes in it tenn?
you mentioned vats and i wanted to ask where the chip is located? i got a complete system from a tpi to put onto my tbi. my tbi is vats and the tpi - including the computer and wiring came from a vats 91. so where is the chip and can i just swap them, so i dont have to get a new key for the car with a new resistor chip on it?
maybe i can go to gm and get the chip with my key and ask for the match.
this is something i never thought of but i like the vats system.
tony
Old Mar 22, 2009 | 11:42 AM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
What would be the easiest and cheapest way to fix this?
Old Mar 22, 2009 | 01:15 PM
Car: 1990
Axle/Gears: stock
did you search this forum and google the problem?
i am doing that right now, but tomorrow morning i will call the local gm dealership and ask the parts guy. he will know.
i just did a search of VATS in this board and got over 1000 individual postings on it.
would like to read them all for you and give you the answer but i think i will let you do it for yourself.
i do remember there was at least one post on how to shut it off, but i cant remember where.
since i may have the same problem i did look a little - https://www.thirdgen.org/vats_passkey_system is one site to look at.
Old Mar 22, 2009 | 01:25 PM
WaltB_FB92's Avatar
Car: Pontiac Firebird
Engine: V-8 305
Transmission: Automatic 4-speed
Axle/Gears: non posi
The amp for the Vette TBI is most likely not the amp for the 305 FB check manuals
on the current requirements.
Old Mar 22, 2009 | 01:28 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
I have been researching and my key doesn't have that little pellet that people have talked about, but I'm using the engine I put in ran with the VATS key and that's what's causing the problem?
Old Mar 22, 2009 | 01:40 PM
Car: 1990
Axle/Gears: stock
https://www.thirdgen.org/forums/elec...able-vats.html is where you want to go.
Old Mar 22, 2009 | 01:43 PM
tinymay's Avatar
Engine: 5.7 TPI
Here's the schematic for an '89. Yours might be a little different. Gives you an idea whats talking to what...
http://i118.photobucket.com/albums/o..._schematic.jpg
Old Mar 22, 2009 | 02:01 PM
Car: 1990
Axle/Gears: stock
excuse me but are you reading any of the links people are putting up for you?
learing about your car is supposed to be part of the fun.
tinymay and waltb are putting up your answers or at least where the answer is.
i posted the link with the answer too.
we are here to help, but not to spoon feed you.
come on the answer has been given to your more than one time.
after you read it, then ask if you still dont know, but i think you will understand.
and if you have read enough to know about the RESISTOR in the key, you should have read how to disable it. i even gave you a link that is titled HOW TO DISABLE VATS and it took less than 10 minutes to find it for you right here on this board.
you remind me of the man who kept praying for God to let him win the lottery. every week he would pray and pray.
finally one day a voice came booming out of the clouds.
the man fell to his knees and asked, god what is it i can do for you.
to which god answered "GIVE ME A BREAK - AT LEAST BUY A TICKET!"
get the point?
Old Mar 22, 2009 | 02:04 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
z28addict8490
Sep 5, 2015 03:56 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Bryan F
Aug 18, 2015 02:28 PM
perZ
Aug 15, 2015 01:17 PM
