need help with compression ratio after head swap
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
so im lookin to do a head swap and im on the hunt for heads now. My motor is from a 91 camaro and im runnin the stock cast iron heads now. The motor was rebuilt and blue printed when i bought it and i have since added all the boltons and a bigger cam. I have been told by the builder that the CR is 9.6-1 now if i go with the new AFR 180cc eliminator heads and had them milled to 58cc how much would this raise my comp ratio and would this be a good idea? Also when you have the heads milled how does this affect the flow numbers on the heads?
Re: need help with compression ratio after head swap
After rebuilding and blueprinting you should have info on:
Piston deck height,
Piston part number,
Cam specs and installation specs ( straight up or... ),
Current cylinder head casting number and head gasket specs ( to double check the 9.6:1 calculation).
From that info you can zero on whether the AFR's are your best bet.
Milling your heads won't affect flow.
Car: 1990
Axle/Gears: stock
with the man above.and dont 58 cc heads fit a 305?
i know that 601 stock heads on a 305 will get the compression up to 10 to 1 but you have to be way above that with 58 cc heads.
but you will need to give us type of pistons, etc.
Car: 92 1500p\u 2wd
ok, i have looked back on the paper work i got from the builder and i dont have much of the info your lookin for but ill do my best. The heads are the stock 91 camaro iron heads, and the head gasket is a factory replacement "what ever that would be" The motor is .40 over with a cylinder clearance of 4.0399 to 4.0404. pistons are seal power hypert flat tops "dont have a part#".....the cam is a comp cams xr264hr-10 specs 212-218@.050 264-270, 110, lift is .487-.495 but im runnin 1.52s for lift is a lil more. as for the installation on the cam im not sure...i had a fleet service shop do the new cam install "my dad knows the owner" and im sure they prob installed it strait up. i have red in the comp cams camshaft installation & degreeing instructions and it says the cam has 4 deg adv grind into it and its best this way for street performance. I wish i knew more...
On Probation
Engine: several
Transmission: none
Axle/Gears: none
In theory you'd be around 10.2:1, and with such a small cam, that might be pushing your luck with pump gas. The AFRs would show a power increase even if you didn't mill them, but even milled, they'll still far outperform any other 180cc heads. Slap them on!
With the info you've provided and what I can find and/or assume:
350/4.04 bore/3.48 stroke.
L98 cast iron heads; 64 cc.
Factory replacement head gasket; .039 x 4.10.
Sealed Power hypereutectic flat top pistons: 5 cc valve relief.
.025" piston below deck.
9.84:1. You would have to measure everything to be precise. I suspect that to be estimated on the high side.
Car: 1992 Z-28
Transmission: auto
Hi Folks
the stock L98 has a compression ratio of 9.5-1 with 64 cc heads - going to a 58c head would give you about 10.2-1 compression ratio.
thanks
Bill
thanks
Bill
Car: 92 1500p\u 2wd
the reaosn i was askin about the 58cc is because the heads im lookin at have already been milled to 58cc...there brand new 1800cc afrs for 1200$ shipped do you think this is a good deal and a good head to get for my setup?
Car: 1992 Z-28
Transmission: auto
is 10.2-1 to much for 91-92 gas? arnt the l-98 cortvettes "113" heads 58cc? there cam is much smaller then the cam in runnin now. Plus im lookin to also do a cam swap down the road to like a 218-224 or 224-230. how would the 180cc AFRs run with these cams?
On my 92, Edelbrock (60CC) heads were cut .010 and runs on 93 ok, my 2002 Z-28 SS (LS1 more like an LS6++) has compression ratio of 11.2:1 and runs on 93 OK. I don't believe you will have any issues.
thanks
Bill
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
