Sequential injection? Reflashable ecm? For TPI? Check here!
Old Mar 31, 2009 | 05:30 PM
kcallais's Avatar
Car: 1985 Z28
Axle/Gears: garbage 2.73
www.weswoodperformance.com located in Florida, has recently begun R&D on their new Digispark system. It offers sequential injection, reprogrammable prom, increased hp/torque/mpg. Theyve tested the system on a few corvettes, and are ramped to begin testing on F-bodies. The kit is an LTX style ecm for quick reprograms, a modified engine harness, modified MAF, and modified distributor. Ive met the owner, Wes, and they are prepared to begin testing. Shoot them tons of emails and perhaps itll get them moving a bit faster =)
Old Mar 31, 2009 | 09:43 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Re: Sequential injection? Reflashable ecm? For TPI? Check here!
i'll take one
Old Mar 31, 2009 | 09:51 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Nice OBDI option, but I would still suggest the OBDII conversion using the 0411. Its just a better all around PCM.
Old Apr 1, 2009 | 08:06 AM
kcallais's Avatar
Car: 1985 Z28
If I remember right, they are using OBDII.
Old Apr 3, 2009 | 06:20 AM
convas's Avatar
Looks nice but I would question why they developed it for a serial only connection, serial ports are not very common on modern laptops, USB would have been a better idea.
Old Apr 3, 2009 | 10:09 AM
kcallais's Avatar
Car: 1985 Z28
I'm going to be meeting up with Wes again this afternoon, I'll bring up the idea of using USB opposed to serial interface. Any other ideas?
Old Apr 3, 2009 | 10:20 AM
Guest
Guest
Posts: n/a
Its already been done.
Old Apr 4, 2009 | 01:20 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Incorporate wideband O2 capablity like an Innovative LC-1. Make it expandable to use distributorless multi coil ignition systems. Incorporate boost control solenoid acctuation. How are they determining the #1 cylinder intake stroke without a cam sensor? That's critical to getting SEFI to work correctly.
Sounds like a cool project, but in reality SEFI is only slightly more efficient than batch fire EFI. It uses less fuel, so better MPG & BSFC numbers. Peak power is the same. You can tune cylinder to cylinder fuel, which is cool, and offers a lot for race guys. For the street it's doubtful you'd notice the difference.
Vintageracer
Jan 10, 2020 05:33 PM
toronto formula
Nov 10, 2015 06:17 AM
Fronzizzle
Aug 19, 2015 01:36 PM
Sanjay
Aug 12, 2015 03:41 PM
marcusaw
Aug 10, 2015 08:13 AM
