Micro Tech MAF Info
Old Apr 2, 2009 | 06:55 PM
Mike Z28's Avatar
Micro Tech MAF Info
I recently installed a non adjustable Micro Tech MAF on my car to try and clear up some occasional caughing through intake and popping out the exhaust (no codes). The maf cleared up these issues but now it doesn't want to run when cold (real rich, and no codes). When warm the throttle response is better than ever. Any input would be appreciated. thanks Mike
Old Apr 3, 2009 | 08:08 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Re: Micro Tech MAF Info
see if you can get a Datalog (Datastream) of the computer and see what its reading. With those values you may beable to figure out what the problem is
Old Apr 3, 2009 | 10:14 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
where is your tps set at
Old Apr 3, 2009 | 10:25 AM
Mike Z28's Avatar
.49 V MAF is around 2560-3200
Old Apr 3, 2009 | 02:12 PM
Car: 91 Trans Am
Engine: 355 TPI
thats too high at idle in park......normal in drive but in park it should be around 1500-1800 roughly, its reading more air which means the computer is saying more fuel more fuel
Old Apr 3, 2009 | 05:20 PM
Mike Z28's Avatar
that 1500-1800 would be for 350ci? this engine is 406, but doing the math still comes out around 2100 grams which is way less than I'm seeing on mine. So, do I still have a MAF issue?
Old Apr 3, 2009 | 06:22 PM
Car: 91 Trans Am
Engine: 355 TPI
very possible, start with the MAF relays, then check your wiring, then change the MAF sensor
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
BumpaD82
Feb 26, 2016 02:57 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
Shane87irocz
Sep 22, 2015 06:21 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
