bosch problem?
Old Apr 7, 2009 | 09:16 PM
Chevhead89's Avatar
bosch problem?
speed density 350 TPI normal bolt ons,cam and 24lb bosch type 3's .ok well the other day was drivin and all of sudden the engine dropped a cylinder. got it home let it cool off and started pullin plugs. well got to number 7 and it was black as could be. all the other plugs looked great!.
so i did a compression check and all my cylinders within 175-185 crankin PSI.
it is passing no oil at all.
changed plug, plug wires, cap and rotor, and also coil.
that cylinder is gettin spark but is gettin so much fuel that it is fouling them out within a minute or so.
so i OHM tested that injector and it is at 16.8 which is right around the others. between 16.8 and 17.
these injectors are only 5 or 6 months old. bought through jon at FIC.
was wonderin if yall have any tricks or suggestins before i call jon up. or put a dang carb on it... thanks in advance
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
greenyone
Sep 2, 2015 03:39 PM
