350 tpi cam HELP
Old Apr 12, 2009 | 07:23 PM
gimpyg001's Avatar
Car: firebird
Engine: 350 t.p.i.
Transmission: auto
350 tpi cam HELP
i have a 87 firebird that i did a 2.8 to a 305 tpi conversion. then i recently did the 305 to a 350 tpi conversion. i believe that i have a bad lifter and while i have it apart i wish to put a new cam a lifter kit in it. what type and how big of a cam i can install with out changing my internals or it messing with my stock computer.
Old Apr 13, 2009 | 06:58 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 350 tpi cam HELP
Is the 350 a roller cam or not
What heads?
Old Apr 13, 2009 | 11:40 AM
gimpyg001's Avatar
Car: firebird
Engine: 350 t.p.i.
Transmission: auto
stock heads. and no its not a roller
Old Apr 17, 2009 | 08:29 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
you can go to Comp Cams website and download a program called Cam Quest. Then all you do is answer a few questions and the program will sort through and pull up all cam profiles that would work with your engine. It will tell you if you need to change computers or not also. I use it, and I think it is a pretty good tool.
Old Apr 19, 2009 | 09:23 PM
gimpyg001's Avatar
Car: firebird
Engine: 350 t.p.i.
Transmission: auto
alright thanks alot
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
