87 tpi tps not working
Old Apr 13, 2009 | 01:29 PM
seventy77's Avatar
Car: 87 GTA
Engine: 5.0
Transmission: 5spd
Axle/Gears: 3:45
I was wondering,can a tps be bad even if it's adjusted right?? Does it affect the idle,or make the idle stick on high if not working? Seeing it tells the computer when your in the throttle.
Old Apr 14, 2009 | 11:04 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Re: 87 tpi tps not working
Yes to all. Get a scanner and see if your getting a smooth flow of tps readings to 4. +
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
fonzie85
Aug 13, 2015 11:50 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Sanjay
Aug 12, 2015 03:41 PM
