Is this motor a good replacement motor?
Old Apr 13, 2009 | 08:40 PM
cryphog's Avatar
Hello all! I have a 1989 Iroc-z with a 350 tpi. Was wanting to know what people would think about replacing it with this http://www.yearone.com/serverfiles/f...DK73488&trk=12. I know I will have to replace the intake with a vortec style intake if i stay with the TPI system!
Old Apr 14, 2009 | 11:42 AM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Re: Is this motor a good replacement motor?
I dont think the cam would get along with the tpi very well.
Old Apr 15, 2009 | 01:21 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
That's the LT4 hot cam. SDPC uses it in their Vortec TPI replacement engine.
Old Apr 15, 2009 | 09:33 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
That's a great motor for your car. The cam is just an LT4 hot cam. It will be a real screamer. If you went with the Holleystrealthram vortec intake it would really move out.
http://store.summitracing.com/partde...5&autoview=sku
CT350PC1
Engine Specifications:
* Horsepower: 400+
* Torque: 400+ ft/lbs
* Compression ratio: 9.5:1
* Dyno-tested: Yes, includes balancer and 14" flexplate
* Dyno sheet: Included with engine's output
* Vacuum produced: 12hg @ 800RPM
* Recommended fuel: 92 octane
* Max recommended RPM- 6000
* Block: Seasoned 4-bolt iron
* Crankshaft: Nodular iron
* Pistons: Hypereutectic
* Connecting rods: Powdered metal
* Camshaft- Hydraulic roller
* Valve lift:.520"
* Duration @ .050" (int/exh): 218deg/228deg
* Rocker arms: Stamped steel 1.6:1 ratio
* Cylinder heads: Ported Vortec
* Valves: Stainless steel 2.02 int/1.60 exh
* Valve springs: Heavy duty
* Bore x Stroke: 4.030" x 3.48"
* Intake manifold: Dual-plane aluminum
* Oil pan, timing cover, valve covers included
* Engine fasteners: High tensile strength
* Warranty: 12 mth/12,000 mi
specialized
Jun 18, 2022 09:26 AM
justin57
Aug 20, 2015 07:05 PM
squiggy2
Aug 9, 2015 09:30 PM
Leggman1
Aug 6, 2015 04:15 AM
NBrehm
Aug 5, 2015 07:57 PM
