head cam.
Old Feb 20, 2009 | 12:06 AM
zealand's Avatar
Car: 1987 formula firebird
Transmission: t5
head cam.
I have 305 tpi and i was wondering if 140414416 (I might buy) heads are better than 14101081(I have but need to be rebuilt)? also I would get a "RV cam" what ever that is with the heads if I buy then. I guess I was wondering if those are better than my stock heads and cam. thanks in advance.
the noob.
Old Feb 20, 2009 | 12:08 AM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
Re: head cam.
The RV cam is ancient, it was popular in the 70's. Decent torque with alright hp. As far as the 416's vs the 081's, they flow pretty much identical with eachother. Plus they both have 1.84/1.50 valves.
Old Feb 20, 2009 | 12:23 AM
zealand's Avatar
Transmission: t5
Re: head cam.
how about the compression? is that the same too?
Old Feb 20, 2009 | 08:12 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: head cam.
dont get sold short on the rv cam
its kind of like a small block chevy
yeah its old but just how much better is the ls1 for the price
just add some 1.6 roller tip rockers and some z28 springs
thats all you need for street rompin tire spinnin goodness
unless you have all kinds of money for overpriced car parts
I suggest save your money for the gas you spend doing a burnout and chippin second
Old Feb 20, 2009 | 08:51 AM
Car: '89 IROC-Z
Engine: LSx
Re: head cam.
They both have 58cc chambers, so yes.
Old Feb 20, 2009 | 11:06 AM
zealand's Avatar
Transmission: t5
Re: head cam.
Originally Posted by jamon8
unless you have all kinds of money for overpriced car parts second
the 416's heads and the cam are both out of a 305 long block for $100
but I will have to look into those valve springs and rockers.
Old Feb 20, 2009 | 04:45 PM
zealand's Avatar
Transmission: t5
Re: head cam.
thanks guys about valve springs could I use ls1 springs my friend gave to me, or would they not work on my heads?
Old Apr 13, 2009 | 01:26 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: head cam.
still have the heads?
thanks tony
Old Apr 14, 2009 | 06:44 PM
zealand's Avatar
Transmission: t5
Re: head cam.
thanks tony
yeah I actually have the whole engine If you are intrested.
Old Apr 15, 2009 | 09:42 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: head cam.
RV cam = High lift low duration, makes more torque at lower rpm, less hp at higher rpm.
neilb
Oct 4, 2018 12:36 AM
mddaniel
Sep 8, 2015 05:16 PM
f-bodyz28
Sep 2, 2015 05:03 PM
z28guy134
Sep 1, 2015 11:50 PM
anesthes
Aug 8, 2015 09:37 PM
