305 TPI mods?
Old Apr 13, 2009 | 08:53 PM
Firebird89ws6's Avatar
305 TPI mods?
I bought a Formula a while back as a weekend cruiser. First 3rd gen and first time working with TPI. I was looking into buying a plenum and aftermarket throttle body and doing some machine work on the plenum. I was also looking at some SLP runners and doing the same with them as well. It's the original engine and only has 67k on it so I don't want to do anything to it I can't easily put back to stock later on down the road. How well do these motors respond these kinds of modifications? Any snags to watch out for? I'm a machinist and welder in the Air Force so I plan on doing the work myself. Any good combos or bolt ons anyone can recommend?
Old Apr 13, 2009 | 10:31 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: 305 TPI mods?
I've got the LB9 aswell. First thing i did was full exhaust (check vBgarage for full details)...I know it helped alot, doesn't pull down nearly as bad starting out in first. Im also getting a custom chip burnt here pretty quick, should add a few ponies.
Next thing is intake, hsr perhaps? vette 113 heads?
Old Apr 13, 2009 | 10:40 PM
goddaor's Avatar
Car: 87 trans am
Engine: LB9 305 TPI
Re: 305 TPI mods?
you may want to look in to the restore stuff you put in the motor oil i put it in my 87 LB9 trans am it has more power and revs faster
Old Apr 14, 2009 | 11:53 AM
NatesZ/28's Avatar
Car: '00 Regal GS/'87 T.A WS-6
Engine: stock 3800 series II/stock 5L TPI
Transmission: fwd auto/stock 700r4
Axle/Gears: wrong wheel drive/3.23:1 Posi
Re: 305 TPI mods?
As with any engine; improve its efficency, get it running as good as it did from the factory and it'll probably wake up a fair amount. My car was very neglected (sparkplugs hadnt been changed in 10yrs, vac lines were cracked). So, replace all of your vac lines, the O2 sensor, Plugs, wires, cap and rotor (brass terminals on the cap), EGR and if youre dismantling the intake, the IAT is probably a good bet as well since youre in the neighborhood. I also replaced my valve cover gaskets and my catalytic converter. Car seemed to wake right up after that honestly. Oh I changed the fuel filter and added a bottle of injector cleaner to the tank. Lots of people have suggested Seafoam engine treatment...just make sure you point it downrange when you fire that car up, it makes a helluva smokescreen.
Oh if youre a fabricator in the airforce (thanks for your service) you could probably buy a bunch of J bends and weld up your own smooth factory style exhaust system. Mine came with a mandrel cat-back (with a flowbastid knockoff which I swapped for an aerochamber muffler).
good luck
Nate
Old Apr 14, 2009 | 12:01 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: 305 TPI mods?
98% of the oil miracle restore is just that.. Basically it is just an oil stabilzer it won't last and it's just a quick fix to an old problem. ... Unfortunetly, if you want more HP, it will starting costing you $$$.. From mild to wild.. Price goes up
Old Apr 14, 2009 | 06:43 PM
F-Body Demon's Avatar
Re: 305 TPI mods?
I agree that you should start on the exhaust. Its probably the best bang for the buck.
Old Apr 14, 2009 | 08:05 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
Re: 305 TPI mods?
i agree with nate get all the basics done first. plugs, wires, rotor, cap, and O2. then go with the exhaust.
If you're doing all the work; port work always will wake it up. when i put on my AS&M runner i ported the plenum and lower base to match. i didn't get track times but the seat-of -the-pants feel gave me a good kick in the but. oh and a fuel pressure reg is good to have to.
just a start
Old Apr 14, 2009 | 09:58 PM
goddaor's Avatar
Car: 87 trans am
Engine: LB9 305 TPI
Re: 305 TPI mods?
i cut my exhaust off at thedown pipes dose not sound so hot but it is faster
Old Apr 14, 2009 | 10:01 PM
Re: 305 TPI mods?
When I got the car, I went through and gave it a full tuneup. I also installed an adjustable Holley fuel pressure regulator. It already had replacement exhaust from the manifold back, but those log style exhaust manifolds look fairly restrictive.
Old Apr 14, 2009 | 10:09 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Re: 305 TPI mods?
Your kidding right
Old Apr 15, 2009 | 01:16 AM
86camaroZ's Avatar
Car: 86 iroc
Engine: 350 vortec HSR
Axle/Gears: 370
Re: 305 TPI mods?
i dont think id cut my exhaust off..
Old Apr 15, 2009 | 02:58 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
Transmission: T-5 WC
Axle/Gears: Yukon 3.73
Re: 305 TPI mods?
First, a tune up with K&N air filter and check and replace any worn sensors (MAF, MAP, TIPS, ICM, EGR, etc.) and an oil change at this time with synthetic oil. You could consider a better distributor, coil and spark plug wires at this time if they are worn. Second, exhaust upgrades (ie headers and bigger and freer flowing exhaust). Third, a camshaft. Fourth, upgrade fuel induction (new injectors, adjustable fuel pressure regulator, throttle body coolant bypass, cooler thermostat and porting work. You do not need a bigger throttle body.) Fifth, new heads preferably done with fourth step. Sixth, new PROM chip.
The Mass Air Flow Sensor (MAF) TPI set ups respond very well to modifications. The Manifold Air Pressure (MAP) TPI set ups starting in 1990 are a little less responsive to modifications.
Last edited by BC GTA; Apr 15, 2009 at 03:05 PM. Reason: throttle body coolant bypass, cooler thermostat
Old Apr 16, 2009 | 10:39 AM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
Re: 305 TPI mods?
stay away from flowtech headers, car didn't pick up a damn thing over manifolds
Old Apr 20, 2009 | 07:34 PM
Re: 305 TPI mods?
What about SLP runners and plenum with siamesed ports along with an aftermarket manifold? I looked at some Pacesetter headers, they look fairly easy to install assuming I don't bust a bolt . At some point I'd like to look into some aluminum L98 heads with roller rockers and aftermarket cam. I'm fairly new to TPI so I'm not 100% sure what combos work best. Luckily it's the high output 305 so it's fairly quick as it is. I replaced the MAF when it took a dump on me. The first thing I did when I bought it was go over everything, but it's in like new condition under the hood with no leaks anywhere. I run Mobil 1 synthetic in all my cars so that was one of the first things I did along with new plugs, distributor cap, wires, etc.
Old Apr 20, 2009 | 10:04 PM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
Re: 305 TPI mods?
Well I would start by getting some hooker 2055 headers and y-pipe to start off. The stock plenum/runners flow more than enough for a stock 305. After headers I would look into cam/lifter kits, just make sure you ugrade your valve springs as well. Roller rockers wont hurt either. After the cam have somewhere like PCM4Less burn a chip to your cam specs etc etc. If your going to spend your time porting something, port the heads.
Old Apr 20, 2009 | 10:57 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Re: 305 TPI mods?
Hows this sound?
**2055s headers and Y, cut out, 3" magna cat back
**LT4 hot cam
**new push rods/springs/retainers/ etc.
**1.6 Full roller rockers
**good tune
Orr89RocZ
Apr 25, 2016 08:28 AM
69 Six Pack
Oct 5, 2015 07:51 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
