At 110 I Hit The Wall! Help, Question About The Governor.
Old Apr 14, 2009 | 08:20 PM
DeathMetalTony's Avatar
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
HI THERE EVERYONE, FIRST OF ALL MY QUESTION IS. ON MY CAR WHEN I DROP IT TO 1ST THN 2ND THEN 3RD BUT AT 3RD GEAR NOT EVEN RED LINEING YET AT 110MPH, I HIT A BRICK WALL. WELL MY CAR STARTS TO PULL BACK OR SO IS THAT THE CAUSE OF THE GOVERNOR OR SOMETHING? THEN ILL SHIFT INTO 4TH AND STILL I CANT GO FASTER THAN 110MPH WHATS MY PROBLEM HERE? RPM'S DONT DROP OR SO.
Old Apr 15, 2009 | 09:27 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: At 110 I Hit The Wall! Help, Question About The Governor.
Top speed is set by how much HP your engine makes, if you are not hitting a rpm or mph limiter. These limiters usually cut the fuel completely and it will seem like the motor shuts off above those limits. After going below the set points everything goes back to normal.
Your "governor" is likely your exhaust, intake, or well worn engine.
Old Apr 15, 2009 | 09:42 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
(OR) It is your governer. I've heard that your governer is set based on your tires. Anyways, the governer basically prevents you from accelerating past its preset top speed, which in your case is 110ish MPH (same with mine).
Old Apr 15, 2009 | 10:00 PM
Engine: 3.0L 2JZGE
Regardless what tires i do have, what can i do or how can i change the governor or limiter so i could go over 110mph?
Old Apr 15, 2009 | 10:12 PM
Stephen's Avatar
Car: 87 GTA
You posted this same question in 5 sections? And I replied in one.......
Dunno if this would work on TPI cars, but I see no reason why. Its just a matter of bypassing the VSS.
http://www.austinthirdgen.org/index.php?pid=7
Old Apr 15, 2009 | 10:19 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
The governor is set in the ECM, you will have to reprogram your chip.
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Yes, bypassing the VSS or I've heard of people reprogramming the computer.
Its not about what tires you currently have installed, its about what tires came from the factory. The speed rating on the tires, if I remember correctly, determined what your speed limiter was set at.
Old Apr 15, 2009 | 11:18 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
But if you plan on going 140+ mph you had better have tires that can handle it or you could be in a world or hurt. Basically if you have tires only rated at 110 mph it is not advised to go any higher than that mph.
Old Apr 15, 2009 | 11:25 PM
rs camaro92's Avatar
Car: 1992 25th anniv. camaro rs
Engine: 3.1L V6
Axle/Gears: stock
I have a question that relates to this. 7 years ago my car would lay its speedo needle on the miles reset button and keep on haulin. Ive done something terribly wrong because now its shutting off at 106. I dont even make it to 110. Did somebody have the chip set before I bought it and I reset it?
evilstuie
Jan 9, 2020 08:29 PM
billybob6110
Sep 24, 2016 09:50 AM
beastin91rs
Oct 9, 2015 07:38 AM
ydnar417
Sep 23, 2015 05:57 AM
redmaroz
Aug 16, 2015 11:40 PM
