87 305 tpi codes 33 and 36
Car: 87 Camaro
Engine: 350 tpi
Hey guys, I have an 87 305 tpi thats been giving me some trouble. Currently I'm getting codes 33 (MAF frequency to high) and 36 (burnoff failure). If I clear the codes, code 33 will set within a few seconds after being started and 36 after being driven. I've tryed switching the relays around which did nothing. I tried all three relays and a spare on the fuel pump and they all worked, so I would assume there good. I replaced the MAF sensor with a reman bosch, made no difference. Today I switched out the computer with one from the junkyard, still codes 33 and 36. However I did notice that with the old computer I had to press the gas to get it to start, and with the junkyard one it will fire right up. I've also tryed to reset the base idle and adjust the tps multiple times, which didn't help. I checked the wires for continuity to rule out any broken wires also. Any Ideas? I'm ready to pull my hair out!
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Re: 87 305 tpi codes 33 and 36
Your maf sensor power and burn-off relays are probably bad.
they're on the firewall near the brake booster.
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I also had intermittent codes 33 and 36, and replacing the MAF relays fixed it. See this thread for relay part numbers and location:
https://www.thirdgen.org/forums/tpi/...nces-they.html
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Do a search on the 33 error code. I have posted several things on this matter over the years.
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
For the code 33, use a paperclip to jump the 5V reference wire to the sensor signal output wire. If the same code sets, it's the wiring. If it sets the opposite code (34 i believe, for it being low), then you have a bad sensor.
Sanjay
Aug 12, 2015 03:41 PM
