TPI IAC
Old Apr 20, 2009 | 05:30 PM
seventy77's Avatar
Car: 87 GTA
Engine: 5.0
Transmission: 5spd
Axle/Gears: 3:45
TPI IAC
Is it possible for idle to get stuck on high because the iac(pintle) is sticking or not coming back in quick enough??
Old Apr 20, 2009 | 06:38 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
Re: TPI IAC
check the throttle cable there are some washers behind the gas peddle that get hung-up sometimes. iac could get stuck if there is alot of carbon build up
Old Apr 20, 2009 | 11:40 PM
boldguy's Avatar
Car: 1992 Z28
Transmission: World Class T-5 5speed manual Trans
Axle/Gears: STOCK G92 performance 3.42
Re: TPI IAC
Yes this is possible. They sell a Noid light/IAC motor Tester (rent from Checker, Schucks, or Kragen) $6.00/day! if you do get a new IAC motor, your gonna have to recalibrate the idle. see the tech article on TPS and IAC adj...
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
86IROC112
Aug 21, 2015 07:20 PM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
