Whats a TPI wiring harness look like?
Old Apr 25, 2009 | 06:59 PM
Awesome-X's Avatar
Car: 87 Camaro
I wanna put stock whatever back in my car but I'm not sure what it is. I think its TPI so I took a pic to see if you guys could verify it..I think its an awful lot of wires for tbi and I know it wasn't carbed. There's also a few on the other side. I'm just glad they didn't cut it all out when they did the conversion..wonder if the tpi's pump is still in the tank lol
Old Apr 26, 2009 | 11:08 PM
Awesome-X's Avatar
Car: 87 Camaro
Re: Whats a TPI wiring harness look like?
Anyone? at all?
Old Apr 26, 2009 | 11:57 PM
snowman383's Avatar
Car: 88 Firebird T-Top
Engine: 350 crate
Transmission: 700r4 w/shift kit
Axle/Gears: one's that move the car
the one three prong plug looks like ether a maf or a tps sensor plug..the others look like they go to the a/c lines that ran on the frame..tps sensor on a tbi would be on the driver side of wiring harness..i will take a pic tommorrow in the light..i have not put my harness in yet for my tbi so you can see it
Old Apr 27, 2009 | 10:28 AM
Awesome-X's Avatar
Car: 87 Camaro
Alright that works thanks alot!
Old Apr 27, 2009 | 12:58 PM
kcallais's Avatar
Car: 1985 Z28
Axle/Gears: garbage 2.73
Depending on what year, 88 and earlier will have a 9th injector plug, and the 89 and later wont. There will be a 3 pin plug next to a square 4 pin plug. Thats the TPS and IAC respectively. The MAF is a 5 pin plug. CTS will be 2 pins, one yellow and one black. Locate these, and it should be a TPI harness.
Old Apr 27, 2009 | 04:28 PM
Pocket's Avatar
Car: 91 Trans Am
Check the numbers on the ECM, if it's still there
You can also compare C100 pinouts as TBI had a unique layout
You're going to have a hard time telling if its TPI/TBI/V6 just from the harness unless you know what each plug is as you look at it or can find 8-9 injector plugs
Also, if its the 87 in your avatar then its original carb, TPI or V6. TBI wasnt introduced until 88
Thinking about it it looks like a TPI harness, namely from the pair or A.I.R. diverter connectors which the V6 didnt have
Old Apr 27, 2009 | 05:00 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
that pic looks like tbi not tpi there's no injector wires or such and what are those lines with the clamps on them where do they go they look like fuel if so tpi ran on the driver's side not the pass side
Old Apr 27, 2009 | 07:06 PM
Pocket's Avatar
Car: 91 Trans Am
Carb cars were the only ones with pass side fuel lines
By the stupid pinch clamps, Id guess those are emission lines rather than pressurized fuel lines
The OP's pic is not the best, maybe the injector wires were cut off or are on the opposite side of the engine
Old Apr 27, 2009 | 11:10 PM
Awesome-X's Avatar
Car: 87 Camaro
All wires are still attached, none have been cut. It was originally a 305, not a V6 and it wasn't originally carbed. I dunno what work was done after we got it I was only 14 and dad did all the work to it all I know is that he converted it to carb. I picked up all the MPFI stuff for $50 a few days ago and I'd like to put it on, but there arent any wires that go to the injectors so unless there was another little harness that attaches to the main one..well I dunno really.
Old Apr 28, 2009 | 04:54 AM
tom86iroc's Avatar
Car: 1986 iroc
it was TBI then NOT tpi
Old Apr 28, 2009 | 05:00 PM
Awesome-X's Avatar
Car: 87 Camaro
Alright well will any GM throttle body and intake fit on this then?
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Caspar
Jun 19, 2016 11:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
Sanjay
Aug 12, 2015 03:41 PM
