TPS setting adapter
Old Apr 28, 2009 | 09:06 AM
TABBOO's Avatar
Top Answer: 1
Car: 87 T/A
TPS setting adapter
I have an old pigtail with the male end of the plug for the TPS & I wonder if anyone knows where I could buy a female plug to simulate the plug for the TPS so I could install this adaper inline with my TPS to set it with a voltmeter.
Old Apr 28, 2009 | 09:31 AM
kcallais's Avatar
Car: 1985 Z28
Axle/Gears: garbage 2.73
Re: TPS setting adapter
Why buy stuff when you can leave everything alone and push the leads from the meter into the back of the existing connector? Cheap and no tools/equipment required other than the meter.
Old Apr 28, 2009 | 09:59 PM
TABBOO's Avatar
Top Answer: 1
Car: 87 T/A
I'd rather not take a chance on damaging the connector.
I can't believe the part I would need would cost more than a few dollars anyway.
Old Apr 29, 2009 | 09:56 AM
kcallais's Avatar
Car: 1985 Z28
Your looking for the sensor side of the connector? If so, and if you have a spare sensor, crack the casing off of the spare sensor and solder the wires from the pigtail to the appropriate lead. The only other thing I can think of is to get some automotive connector pins, crimp them onto your pigtail, and hand insert the leads into the engine harness.
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
87iroctheo
Wheels and Tires
Sep 2, 2015 03:29 AM
mdtoren
Aug 23, 2015 12:52 PM
