Retarded timing HELP!!
Old May 5, 2009 | 12:41 PM
Brads RS's Avatar
Ok I have a 92 TPI Camaro with a 355 and mild cam. The engine had been running fine but i started to notice the engine starting to knock under a load. I traced it down to the timing. The timing never advances and is out of the timing marker on the retarded side when it is running, and out of site when you put the engine under a load. Its kinda like its doing the opposite of what it should be doing. I have tried a new ecm, new prom, new dist. module, new knock sensor, and cannot under stand whats making it retard the timing so much. If i unplug the timing advance wire and run base timing its fine, no knock and its rock steady on 6 degrees. I'm at a loss i'm not sure where else to go. The only other thing that i should mention is the car was a 6 cylinder and i re wired it for the v8. I will be double checking the wiring to night but i doubt the problem is there since this problem has just showed up and it worked fine before. Any direction would be great. Thanks in advance, Brad
Old May 6, 2009 | 08:08 AM
Brads RS's Avatar
Re: Retarded timing HELP!!
If this is the wrong board would one of the mods please move it to the right one. I thought for sure that someone has had to come across this problem.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
