Steel Wool and elbow grease
Old May 24, 2009 | 11:15 AM
Kebos86's Avatar
Car: 1986 Trans Am
Engine: 305 T.P.I
Transmission: TurboHydramatic 700R4 4 speed autom
Axle/Gears: ?
I keep hearing all the different buffers and polishes you have to use, my intake is nothing but, 1- degreaser, get the crap off and get it clean, 2- 400 grit to remove pits and scracthes, 3- steel wool, work down from 00, 000, then finally 0000.
Attached Thumbnails Steel Wool and elbow grease-before.jpg   Steel Wool and elbow grease-almost-done.jpg   Steel Wool and elbow grease-waiting-install.jpg
Old May 24, 2009 | 11:21 AM
ls six's Avatar
Re: Steel Wool and elbow grease
Now you need to seal it somehow or it'll oxidize and you'll either have a nasty intake or you'll be doing it again.
Plastic coating, powder coating and anodizing can all be done at home for cheap if you look it up.
Old May 24, 2009 | 11:29 AM
Kebos86's Avatar
Car: 1986 Trans Am
Engine: 305 T.P.I
Axle/Gears: ?
Thanks, I was kinda worried about what it will look like in time, definetly dont wont to redo.
Old May 24, 2009 | 12:15 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
i would have used some sandpaper in the beginning to get rid of the casting finish.
if you look close, you can see some orangepeel finish going on, but it is definitely better than stock.
good job.
to finish mine up, i used a product called "heavy metal polish"
you should try it out.
it will make it shine like a mirror
Old May 24, 2009 | 12:17 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
that is really fine looking - i will try it with my stock.
how long did it take?
Old May 24, 2009 | 12:23 PM
Kebos86's Avatar
Car: 1986 Trans Am
Engine: 305 T.P.I
Axle/Gears: ?
Heavy metal polish applied with just a cloth ?
Also what did you use to seal, Im worried it will lose its shine.
Yes could have sanded a little better. One runner took about six hors including breaks. Cleaning took a while, was worried about denting or scratches. Also everytime I thought it was done and bright enough I would start over again with 0000 and it would shine up even more.
I wanted to do the plenum also then changed my mine and decided to paint it the same color as valve covers.
Attached Thumbnails Steel Wool and elbow grease-100_0900.jpg   Steel Wool and elbow grease-100_0954.jpg
Old May 24, 2009 | 12:52 PM
Car: 1990
Axle/Gears: stock
do you think you could use paint like the high temp stuff you would use on brake calipers? you can get it in spray cans.
and i found this site posted by someone else here - SPILLS of third gen. he rightly refered to as the holy grail of power coating. http://forum.caswellplating.com/powd...ing-questions/
found a clear coating site that is heat resistant - or so they say http://www.levineautoparts.com/seyhigtecglo.html
found another one http://www.westmarine.com/1/1/5930-e...m-moeller.html.
got one more http://www.thefind.com/crafts/info-engine-enamel-paint.
last one http://www.iboats.com/Marine_Engine_...view_id.217339.
Old May 24, 2009 | 01:06 PM
Kebos86's Avatar
Car: 1986 Trans Am
Engine: 305 T.P.I
Axle/Gears: ?
Thats where im stuck, Id like a clearcoat I can trust not to ruin ceramic enamel or dull the aliminum.
Old May 24, 2009 | 01:34 PM
Kebos86's Avatar
Car: 1986 Trans Am
Engine: 305 T.P.I
Axle/Gears: ?
Thanks on the links, I think Im headed to the parts supply store to see what they have in stock or recommend.
Old May 24, 2009 | 02:12 PM
Car: 1990
Axle/Gears: stock
be sure to tell us what you get and if it works. some pics about work in progress would be great. they look great. how many hours did it take? did you use any machine work?
Old May 24, 2009 | 08:15 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
you know, honestly...
i just put the heavy metal polish on with a soft cloth and its been 2 months since and it hasnt tarnished at all
granted i went down to 1200 grit sandpaper before i used polish, so it was almost a mirror before, but the polish got rid of the swirls that showed up in it.
if you were super crazy about it, put heavy metal polish on once a month (use about the same amount you would put on a toothbrush) and you will be set.
Old May 25, 2009 | 08:21 PM
Kebos86's Avatar
Car: 1986 Trans Am
Engine: 305 T.P.I
Axle/Gears: ?
From what I've been reading any kind of coating is gonna dull down the luster, I think polish once a month is going to be the cleanest look. I'll through up some pics once I get her put back together. This is my first do it all myself rebuild, so I will probably be a little bias on the results.
3rdgenparts
May 21, 2016 11:50 PM
darwinprice
17
Oct 11, 2015 11:51 PM
skinny z
Oct 5, 2015 06:23 PM
roysatikas
Sep 22, 2015 08:15 PM
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
