Roller rocker problem
Old May 25, 2009 | 05:39 PM
TPeye's Avatar
Car: 1992 Camaro Z28
Engine: 350ci
I just put in comp pro magnum 1.6 roller rockers, and they are noisy. I adjusted them one cylinder at a time making sure that the rocker being adjusted was on the base circle of the cam. I tightened the rocker until the pushrod could not be jiggled up and down and then gave it another 1/2 turn for preload. It's louder than a solid lifter setup and just sounds terrible. Are these rockers supposed to be like this?
Old May 25, 2009 | 08:50 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Re: Roller rocker problem
I would readjust them and increase the pre load to almost 3/4 turn.
Old May 25, 2009 | 10:29 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
i'm not sure if what your experiencing is normal ,but i ran mine 1/2 a turn preload and readjusted and readjusted from 1/2 to 1 turn tons of times on a fresh motor with jegs brand roller rockers, they still sound noisier than the factory stamped style, just my experience though.
Old May 27, 2009 | 11:17 AM
TPeye's Avatar
Engine: 350ci
Adding more preload did not stop the noise, so I put the original rockers back in. It's still ticking, so the noise is not coming from the rockers. Here is a clip of the ticking.
File Type: mp3
Old May 27, 2009 | 11:33 AM
dustpusher's Avatar
Car: 88 IROC-Z
From that clip it sounds like an exhaust leak.Maybe it sounds different in person?
Old May 27, 2009 | 04:01 PM
TPeye's Avatar
Engine: 350ci
It's amazing. Whenever I change one thing, something else always breaks at the same time. I was able to trace the problem to bad exhaust manifold gasket.
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
