Stock 85 TPI Knock Sensor Wire color?
Engine: None
Transmission: None
When I bought my 85 Trans am the knock sensor had been disconnected with no harness on it. I know that the wire runs to the ESC located on the driver side firewall. The color coming off the knock sensor is blue and there is a blue wire coming out of the connector at the ESC. Is it safe to assume I can just connect the two and it should work? Thanks for the input.
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
Re: Stock 85 TPI Knock Sensor Wire color?
Yes, Dk Blue goes directly from the ESC module to the knock sensor.
HTH
HTH
Engine: None
Transmission: None
Thanks for the reply. I've already patched it in but not sure if I would notice a difference or not while idling due to the car being on front jackstands(waiting for new tires to arrive).
Linson
Aug 21, 2015 02:12 PM
