1991 Camaro RS V6 3.1 TPI Starts and then dies
Old May 27, 2009 | 03:28 PM
emerrem's Avatar
My baby is in bad shape and can not locate the problem, it was running just fine, then I decide to sell it because I found another one in better shape, when I finaly get a buyer starts acting up, first the brand new A/C compresor goes out, after replaced the engine started to stall, like when cold it will start fine then after a couple of minutes dies, I checked, from AIC valve, MAP sensor, TPS, ECM, computer, oil switch sensor, fuel pump seems to be working, injectors are hot, fuel filter is new, no codes at all.
Now it will start but in a matter of seconds it will fail and then die, every time will start but then die, fuel presure is good , it seems like something kills the fuel pump, but I can hear the pump after the car dies, should replace the pump anyway, Is been there for aboy 3 years. I really need help. Please.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Jlanz55
Sep 29, 2015 08:55 AM
ironbmt
Sep 27, 2015 06:00 AM
Lmancha96
Sep 25, 2015 08:11 PM
