Gasoline
Old Jun 5, 2009 | 10:29 AM
thelastz28's Avatar
Gasoline
Dumb question..... I have an 88 GTA 5.7, am I supposed to run premium gas or can I run regular or mid-grade? Thanks for the help.
Old Jun 5, 2009 | 12:06 PM
aweTastic's Avatar
Car: 1989 Camaro IROC-Z28
Engine: Rebuilt 350TPI (see sig)
Transmission: is being replaced...
Axle/Gears: 20 year old G92 Borg-Warner 3.45
Re: Gasoline
Well assuming you have a bone stock unmodified L98 then you should be able to run regular unleaded
Old Jun 5, 2009 | 12:49 PM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
Re: Gasoline
nothing saying you cant run a higher than regular grade. running a higher grade will give you slightly better MPGs.
Old Jun 5, 2009 | 02:22 PM
thelastz28's Avatar
Re: Gasoline
The car has SLP headers and a 3" catback.
Old Jun 5, 2009 | 03:46 PM
aweTastic's Avatar
Re: Gasoline
While you can run a higher grade of fuel its not necessarily true that youll get better mpgs but you should get better emissions lol
If thats all thats done than regular unleaded is fine... where you want to be concerned is if your timing is different then stock or if you have increased compression...
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Justin92GTA
Aug 27, 2015 11:16 PM
carrascoZ28
Jan 9, 2003 11:18 AM
Jer82Z28
Sep 26, 2002 06:14 PM
Sciguyjim
Jul 8, 2002 05:17 PM
