Tpi leaking
Old Jun 9, 2009 | 07:55 PM
ngonnelly's Avatar
Car: 1990 Camaro IROC-Z28
Engine: 5.7L 350cid
Transmission: auto
Axle/Gears: i think 3.42
Tpi leaking
I torqued it to 35 but didnt do it in the rite order i thought i did but it was complety off first one side then the other hayns told me to so yea any way could thay b y i got coolent in my oil or does that point to a way worse problm like crack
Old Jun 9, 2009 | 11:07 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Tpi leaking
Yea a leaking intake manifold could definitely cause water in the oil. I'de recommend pulling the intake using a new gasket. Other things you may have overlooked is cleaning out the threads on the bolts and in the head. If there not perfectly clean it will throw off your torque values when you go to bolt it up. Also don't forget to use thread sealant as some of the intake bolts go into the water jacket. Also use the gasket sealer as recomended by the directions included with the intake manifold gasket.
Old Jun 10, 2009 | 11:05 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: Tpi leaking
First of all, what did you torque to 35? (the cylinder heads?) And was that ft-lbf OR N-m? Did you use a gasket? What gasket? Did you use any sealant? We could help you a lot more if you would write down precisely what you are doing.
bamaboy0323
Sep 3, 2015 06:07 AM
TheExaminer
Aug 26, 2015 04:59 PM
wayshegoes
Aug 17, 2015 12:00 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
