E3 spark plugs performed awful
Car: 1991 CHEVROLET CAMARO Z28
Engine: 6 LITER after rebuilding :)
Transmission: 700 R4
Axle/Gears: 3.23 / 9:7:1
I tried those E3s but as soon as I started the car, it was shaking really excessively so I changed them back to standard Autolites and everything went back to normal. I am sure I purchased the correct ones for my car as they are unadjustable.
Any similar experiences? Something to do with E3 design that does not fit our camaros maybe..? Too much sparking..?
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Re: E3 spark plugs performed awful
Run Delco plugs first
If unavailable run Autolite.
Trust people who race, been around it and use lots of boost.
I go with what I know, have seen and others know worked.
Never run into problems that way.
Car: 1988 Pontiac GTA
Engine: 5.7 w/SLP cold air intake
Axle/Gears: 9 Bolt 3.27 with PBR brake upgrade
I installed E3's on my 1988 L98 and they work great - idle was smoother than with the original plugs (57K). No issues at all. HP TV did a dyno run using these plugs and they seemed to perform well. I don't like the fact that they are made in China. I agree that Autolite makes an excellent plug.
Car: 89 Firbird Formula WS6
Engine: TPI 305
Transmission: T 5
Axle/Gears: 3.45 Posi 9 bolt
HP tv is nothing but a long commercial. And yea any new plug will perform better than plugs that have been in a car for 57k miles
Car: 1987 IROC
Engine: 350 Gm H.O
Transmission: 700r4 built
Axle/Gears: 3.42 Locker
Bad luck here with them to. My 305 shook with them. I changed over to autolite and have had no problems. My brothers Jeep cherokee 4.0 had its oil pressure raise a lot with them too. I say don't mess around with spark plugs and stay with what people have had good luck with.
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
yeah, just a sales gimmick. Just like those "pulse" sparkplugs... you can't reinvent the wheel...
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
LOL. And I thought I was the only one thinking that block of programming was just advertising and some...good ideas. Talk about pushing Royal Purple and O'Reiley auto parts.
Car: 1991 Trans Am
Car: 1987 IROC
Engine: 350 Gm H.O
I have no idea. But his oil pressure gauge went as high as it could go and his engine always ran hotter than normal. I thought his gauge was broken. Two weeks later when we put the stock plugs back in the gauge went back down to normal. I wish I knew. Maybe somebody else could give some incite on how this could be?
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
changin the plugs, you probably fixed the connection on the oil sending unit, when the harness is unplugged from the sending unit, the gauge will always be maxed. so the plug was probably loose and someone touched it just right to correct the connection. nothing magic here.
Car: 1988 GTA
Engine: 305 tpi (LB9)
Transmission: WC T-5
Axle/Gears: 3.45 posi
I put E3s in my 88 GTA LB9 and love them. The car idles smoother and I can tell a difference over AC Delco rapidfires, especially at highter RPMs. Did you replace the other ignition components or just the plugs? Sometimes the wire terminals pull loose on the inside when you take the boots off of the plugs. I was skeptical about these plugs but after running them I probably won't use anything else.
evilstuie
Feb 28, 2016 03:33 PM
