need help with cam selection.
Old Jul 15, 2009 | 11:49 AM
SebringZ's Avatar
I have an accel cam installed on my 305TPI. I love the idle and powerband, however I'm almost certain forced induction will help get everything out of it. Bottom end has been rebuilt. L98 aluminum heads along with aftermarket base,stock runners. Possibly in a couple of months I was going to go with a procharger kit(6-8psi)Intercooled. Should I stick with this cam? It is an 87' LB9 block and was wondering if I chose the right cam. Compression is 9.5:1. Thanks!
Here are the specs of the cam that I have.
Duration @ .050" lift: 211/219 (int/exh)
Valve lift: .499"/.525" (int/exh)
Old Jul 15, 2009 | 01:50 PM
spicy chicken's Avatar
Car: 1988 trans am gta
Axle/Gears: 9 bolt
Re: need help with cam selection.
i dont know about the cam but where did you find the procharger kit? ive been having trouble finding them (probably doesn't help that jegs is down right now)
Old Jul 15, 2009 | 02:14 PM
bigdavesiroc's Avatar
Car: 87 iroc
Engine: 410 sbc
Transmission: tremec 3550
Axle/Gears: 30 spline 3.73
i would think your cam would still be good since your still running the stock style intake. i know you have a better base but stock runners. i would definitely put a bigger cam in if you went with say, holley hhr, or miniram. with the supercharger you should extend the peak rpm by 200/300. put you around 5000-5100.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
