Just can't dip into the 11's
Old Sep 1, 2011 | 08:55 AM
  #101
Big Dog Chevy's Avatar
Car: A lot and 86' Z28 and 88' Camaro
Engine: 305, 383 and 565
Transmission: 700R4, th400 and 4L80
Axle/Gears: Frd 8.8 /3.27 and S60
Re: Just can't dip into the 11's
I would try pulling some weight and doing other things before I go thru the hassle and money of a cam swap. You are only a tenth away from your goal.
Old Sep 1, 2011 | 08:59 AM
  #102
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
That would be logical too. Keep playing with it and see if you can find some power somewhere in the combination, or get the 60ft to improve, or get weight out of it.
Another thing you can try, retard the cam 2-4 deg with an adjustable timing setup. That may free up some top end power and get you another tenth or 2 without any money.
Old Sep 1, 2011 | 09:04 AM
  #103
The cam retard will be a good idea. If he has torque to spare down low then he will not loose his 60' but pick up rpm, top end and mph.
Old Sep 9, 2011 | 06:57 PM
  #104
gixxer9's Avatar
Car: 86 IROC
Engine: 6.2
Axle/Gears: 10 Bolt 4.10
joeblue83, what are you running for injectors again? Weren't they 30 lbs at some point?
Old Sep 10, 2011 | 10:09 AM
  #105
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Yup accel 30 lb inJectors
Old Sep 15, 2011 | 08:40 AM
  #106
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
I was thinking over the winter to gut the maf and upgrade my 52mm throttle body to a 58 mm throttle body. Anyone think I would make anymore power, or should I go in a different direction.
Old Sep 15, 2011 | 09:24 AM
  #107
That will only help if those items are holding you back, if not then it would be a waste of time and money.
Old Sep 16, 2011 | 11:11 AM
  #108
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
If you do upgrade the throttle body, I recommend the Holley Billet 58mm. I havent had good luck with the BBK's...
Old Sep 16, 2011 | 02:20 PM
  #109
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
If it does make anymore power it wont be noticeable IMO... you still have the MAF to suck through which is more of a restriction than the TB.
I'd retard the cam 4 deg and see if it picks up power. That motor wants more cam with a miniram on top
Old Sep 17, 2011 | 09:06 PM
  #110
88BlackZ-51's Avatar
Originally Posted by Red89C4
My buddies combo of .... Stock CID, OEM 113 Alum heads ported by TPIS, Mini Ram, Hooker headers into Flowmasters, 3.73 rear, 4000 stall converter & TPIS ZZ09 cam, has gone 11.23@121 in a 1989 Corvette. I'm surprised yours has not run faster then it has.
Was Vic's DA -1500 on that run? Also Vic has a very light C4 compared to an F-Body.
InfernalVortex
Apr 20, 2021 11:31 AM
Amillionoh7
Sep 26, 2015 09:45 AM
david068513
Sep 18, 2015 10:36 AM
the_nikfive
Aug 11, 2015 02:46 AM
jeff
Nov 2, 2001 10:57 AM
