EGR temp sensor has been discontinued
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
Re: EGR temp sensor has been discontinued
why dont you just buy http://cgi.ebay.com/ebaymotors/ws/eB...d=270534835463
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello All!!
The item will work the same way, at the same temperature, however the other part #14087416 for our F-bodies has the white clip on it, and the wire is longer!! Therefore as is, in theory it will work, but in reality, it won't!!
Modify it, (extend the wire) and it will work!!
You just had to show me that, didn't you!!
I paid $50.00 x 3 for three of them in December, from Autopartauctions.com in Texas!!
Now there they are for $13.16 each!!
sorry >.> oh well let the buying craze begine again! wanna be pissed off? i threw a peerfectly good EGR temp sensor away last summer (accident)
I feel like buying some more of these, it would be a steal at $13.16 each!!
Always keep track of your errant EGR Temp Sensors, you never know where they will end up, by accident!!!
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Nice to see you guys have an option now. To bad my buddy had to sell his IROC because of this problem and not being able to pass emissions because of the check engine light. Well glad your all good to go now.
Since this is important to the external EGR I'm fabbing to use a Miniram on a 88 GTA, did I read correctly and the vette switch goes in the tube from the exhaust to the back of the intake before the EGR valve and not in the valve like the FBody unit?
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
good question. Im baffled too.
Car: 87 T-Top GTA
At $50 ea. we all got taken for a ride!!!!!
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
The EGR valve on a Vette TPI is located in the same position under the plenum but the exh gases to it come from the pass side exh mainfold , through the crossover tube ( w/ switch ) shown above then through a internal passage in the base to the valve
Well said vettoz. I didnt know there was such a difference between the vette intake manifold compaired to the other TPI intakes.
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
First I wanna say i am having Nox issue which I feel are EGR related and this thread has been quite helpful!
That being said, my car is 91Z factory 350 TPI car and i have the old style two round pin connector not the newer "metra pack" style, I found that odd. Anyway, just thought I'd share.
Car: 87 T-Top GTA
Hello y84pauloflondon!!
Your taking the fun out of this!!
I figured it out, the packaging is worth more, see formula ($15.00 part + ($35.00 for packaging) + $24.00 s/h = $74.00 CDN !!! A steal of a deal!!
Car: 87 T-Top GTA
Take a look at this item http://cgi.ebay.com/ebaymotors/ws/eB...85780106838105
Notice the California sales tax which is 9.25%. Well I live in California and to my knowledge, here in my county (Imperial Valley), the sales tax is 8.75%. Is it possible that this ebay store is abusing and trying to make a profit by posting a high tax?
Lol, im going to get you that part number on my lunch break tomorrow paul, I have not forgotten you!
Check your tax rate again!!
You have different tax rates for different counties, maybe they charge the highest California, County Tax Rate, just to make sure they aren't ripping off Uncle Sam and his brother IRS!!
not even camaro related
. Senior Member
cook county sales tax 10.00%
[quote=Chevy8588;4462479]cook county sales tax 10.00%[/quote
Hello Chevy8588!!
British Columbia provincial tax rate 12% = 7% for the Province, and 5% for the Federal dudes!!
Hello Chevy8588!!
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Wow. From EGR Temp Sensor availability, to taxes, to someone's sister (Uncle Sam's). Very nice subjects.
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
At least it took a while for this thread to get derailed. Hats off to the Mods.
You should try the forums at www.bobistheoilguy.com. It takes maybe three posts before the train runs off the tracks.
Like this thread:http://www.bobistheoilguy.com/forums...21#Post1808021
Hello All!!
If the "posts" in the thread have a natural progression and are related to one another but don't mention the subject line, can't you say that the thread is not derailed, but mearly it has taken a different spur?????
The train is running.....however, it's not stopping at my town ("EGR Temp Sensor Has Been Discontinued"), because it's on another spur line!!! It's all related in a convoluted way!!!
Someone is bound to get it!!!
Gotcha!!
Gotcha!! Joined: May 2009
Hello All!!
Gotcha!!
Gotcha!!
. I still agree that the train has derailed. The last subjects are in fact a progression relating to the thread, but the thread clearly states what the subject is, and as for the recent posts, (including this one) has nothing to do with the subject at hand. But who cares..... I just confused myself in my own post.
. I just gave myself a backhand.
I felt that backhand!!!!
Never to derail the thread again, until the next time!!!
It shouldn't matter since I think most older cars like ours are exempt from emissions right? Here in Missouri if your car is 1996 or older you're exempt from emissions but not safety inspections.
If only that was true everywhere. AZ is 1966 or older to be exempt or insured as a limited use collector car. Everything else goes through various emissions tests based on age.
Here in CA, i was exempt for emissions, and I got a 86.
Dang, they sure are making money off of people then. Over here I pay $23/month full coverage insurance on my IROC-Z & I don't have to do emissions but I HAVE to keep the emissions parts on the car I think.
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
guys, i may have found a site, ill try ordering one up and see what goes from there!
The site was http://www.dmauto.com/web/dmauto/Cat...fg/CRB/229130/
but like always, ive ordered it up, and they send u a part is discontinued mail as followed.
Hi Jeffery
Thank you for this order – but unfortunately the sensor has been discontinued and is no longer available. We tried to get it in Delco and Standard but they discontinued the item also. I’m sorry we could not help you
Regards,
Rose Collaro
Rose Collaro
D & M Auto Parts Corp.
56 Engineers Dr.
Hicksville, NY 11801
Ph: 516-822-6662
Fax: 516-822-5020
Hi Jeffery
Regards,
Rose Collaro
Rose Collaro
56 Engineers Dr.
Ph: 516-822-6662
Fax: 516-822-5020
After some trouble shooting I am almost sure my EGR temp sensor is bad. I tried to by a new one and have been informed that they are no longer being manufactured for TPI cars 87 to 89.
GM # 14087416 Discontinued, no old stock remaining in the country.
AC/Delco # 212-337 - Discontinued
Standard Automotive # ETS2 - Discontinued
Kem Automotive # 140-223 - Discontinued
Delphi # TS10113 - Discontinued
Pep Boys Borg Warner # EGR301 Discontinued
Autozone Duralast # ET101- Discontinued
NAPA # CRB229130- Discontinued
So now what am I supposed to do? Looks like the check engine light will be on for a long time. Some much for complying with emissions.
HERE IS THERE INFO.
KAY AUTOMOTIVE - VAN NUYS (ACDELCO) (818)781-6850 14650 CALVERT ST VAN VUYS, CA 91411
KILLENS CHEV-OLDS-PONT INC (601)683-3381 501 NORTHSIDE DR NEWTON, MS 393452020
AHHH. You help me by telling me to call Collin pertaining the seat belt recall but,,,,,,,,, you throw me under the bus for a discontinued part. So much for the help that were suposed to give eachother here on the messageboard.
the place in california laughed at me and said try ebay. haha
I'm always trying to help out fellow thirdgeners!!
I didn't throw you under the bus for a discontinued part!!
I saved you from the raging mob of discontinued parts chasers!!!
On a serious note, I checked autopartauctions.com and found nothing this time, they must have all been bought up!!
You should have bought one for $50.00 in December/January like y84pauloflondon, and I did!!
Your going to find out that these don't pan out!!!
Extremely lucky if they do!!
Car: 87 T-Top GTA
Good Luck! A fellow member tried Many different dealers already, and of course... no part could be found. The problem is that the dealers don't always keep their part supply listings up to date!!!!
Hello Chevy86 IROC-Z!!
