mis-fire 350 tpi when cold
Old Jul 27, 2009 | 06:08 PM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
ok my 87 350 tpi seems to have a mis when its cold.After it warms up to normal temp it seem to go away? The mis/stumble is only at the crack of the throttle.Im thinkin maybe intake gasket, runners or injector??Any help would be great...
Old Jul 30, 2009 | 03:01 PM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
Re: mis-fire 350 tpi when cold
bump
Old Aug 19, 2009 | 09:12 PM
Sully89Firebird's Avatar
Car: 1989 Firebird Formula
Engine: Stock 305 TPI
Transmission: 700R-4 w/ Shiftkit
Axle/Gears: Stock 2.73
Originally Posted by DA BRONX
bump
OHM your injectors, they should not be less then 12 and the tolerance is 0.5.
Old Aug 20, 2009 | 01:09 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I have a similar problem when I first start the car in the morning and drive away. When leaving from a stop the first few times it has a stumble. Im not sure whats causing it, but when I find the problem i'll let you know.
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
