W.O.T. PROBLEM!
Old Jul 27, 2009 | 10:50 PM
Americanmouse's Avatar
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
W.O.T. PROBLEM!
At W.O.T. right before the engine shifts at 5300-5600rpms it bogs down/stumbles into the next gear then it picks right up til right before the next shift and does it again.
My trans is a rebuilt700r4.
ENGINE STATS AS FOLLOWS:
383 L98 TPI
Engine:
350 bored .030 over truck block 4 bolt main, line bored, magnafluxed, cylinders honed
engine internals balanced
Engine Modifications:
Stock plenum ported/simeased for the runners and throttle body
Edelbrock intake manifold and runners ported and simesed
Edelbrock Performer heads ported 64cc & 160/202 intake/exhaust
Edelbrock Valve Covers
Moroso valve cover breathers
Edelbrock BBK 58mm Throttle Body
Racetronix 37lb. Injectors
Walbro high performance fuel pump
Holley adj. fuel pressure regulator
Manly Pushrods
Crane 1.6 Roller Rockers
Comp cam Hydraulic roller:
510/540 gross lift 1.6 rockers bump up lift to 576
Duration at .050 intake:230/exhaust244
Lobe separation:112
Federal Mogol Sealed Power Speed Pro 10:5:1 forged pistons
Sealed Power Chrome Molly rings
Eagle forged piston rods
refurbished truck 400 crank turned down polished and balanced
Power Force harmonic balancer
Moroso 6qt. Pan
Edelbrock water pump
MSD HEI distributor with cap & rotor
MSD Blaster coil
MSD box 6AL with rev. limiter
Accel 8.8 wires with heat retarded sleeves
Autolite short plugs for header clearence and cooler heat range
Hooker 2210 long tube coated headers 1 3/4
Mufflex 3.0" Exhaust System
3” Flowmaster Race Series muffler
SLP cold air induction
K/N air filter
Grantanelli adj. Mas air flow sensor
Old Jul 28, 2009 | 09:08 AM
Car: 1988 IROC-Z28
Re: W.O.T. PROBLEM!
Also I did reset the IAC, and set the TPS at .054. I have rasied the idle to 8-900rpm in park, and in drive its about 750rpm.
Old Jul 28, 2009 | 08:05 PM
Car: 1988 IROC-Z28
Re: W.O.T. PROBLEM!
Well I e-mailed Racetronix where I got my injectors from asking them about fuel pressure. They said I should be good at 43.5PSI, I have mine set at 45-46PSI. So I'm going to lower down to 43PSI and see if that fixes the problem.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
