Diagnosis: bad injectors
Car: 82 Camaro Pace Car & 1989 IROC
Engine: LG4. & 350 TPI
Transmission: 200C
Hi, I realize this question may have been answered a few times, but here it goes:
* I need new injectors for my 1991 Camaro, 305 auto. I was told that I can go with Accel. Is this correct? What size injector? I was also told that they come in black now (as opposed to only yellow) as I want the stock appearance.
Can anyone point me to the link where I can buy these?
Any other friendly advice?
Thx
Ron
Thx
Ron
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
Re: Diagnosis: bad injectors
I replaced my injectors with 22 lb Bosch III's from fuelinjectorconnection.com. The Bosch III's work great. Contact Jon and he'll fix you up at a good price!
Car: 89 iroc
Engine: l98
Transmission: tremec
Thx
Ron
Thx
Ron
Car: 1989 Pontiac Trans Am GTA
Engine: 5.7L L98
Axle/Gears: 3.27:1
Just wanted to put my 2 cents in for the Bosch III's from fuelinjectionconnection.com. You can't go wrong with them and they're a breeze to install. Good luck!
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
i agree,fuelinjectorconnection has the best service i've ever experienced
im overseas and Jon himself called me to assist me on the installation when i was making some mistakes,i did a nice step by step installatio and im very grateful to them
they have a STRONG following on the Corvette forum as well.-
Here's the contact info
Fuel Injector Connection, LLC
4966 Wade Valley Way
Cumming, GA 30040
Tel: 770-888-1662
Jon at FIC http://fuelinjectorconnection.com/shop/
had the luck of purchase from FIC,you won't go wrong with them
I recommeded him with my TPI friends that went to Bosch III's and i swear we have never looked back or choose another provider !!!
now i got a set of Blue pearl ZR1 style injectors for my L98 !!!!
I stand by my words and FIC is the right choice !!!
Check this thread to se my injector installation video
check this out :
Cumming, GA 30040
Tel: 770-888-1662
check this out :
Transmission: 200C
So that means I don't need 24lb injectors but can get by on 22lb ones from Bosch?
What would the performance difference be?
Also, what are the original GM ones...22lbs also?
Ron
Ron
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
if you have a 305, you need 19lb/hr injectors. If you have a 350, you need 22 lb/hr. stock for the 305 is 19lb/hr. stock for the 350 is 22lb/hr
Car: 89 T/A
Engine: LB9
True stock injectors for the 305 are 19 lb...but again the Bosch III's work fine with no trouble from the computer.
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
agreed.. jon at FIC rocks. have had a set of the type III bosche for a year now and they work great
ambainb
Apr 25, 2016 09:21 PM
