code 45
Old Jul 29, 2009 | 09:29 AM
zcam96's Avatar
Car: 1989 irocz lb9 57k miles
Transmission: manual
code 45
I'm new to fuel injection and have a 1989 IROC with a 305 TPI. I get a code 45...rich indication and the idle fluctuates between 1000 and 600 rpm, and ther is a strong smell of fuel. The fuel pressure is in specs as well as the new TPS and 02 sensors. I checked the injectors and all read between 16,2 to 16.8 ohms except one which read 8.3 ohms. Could this be the cause of the code 45? Any help will be greatly appreciated!!
Old Jul 30, 2009 | 07:25 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: code 45
Its very possible that that is the cause. However regardless of weather it is or not you still need to replace them.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
