help with code 32
Old Jul 29, 2009 | 11:09 PM
topradman's Avatar
Car: 91 Z28
Engine: Super Charged 414 FI Roller Mtr.
Transmission: CK Perf. 4L80E Manual W/Transbrake
Axle/Gears: 9" Ford 3.25
help with code 32
Not sure on this but had a custom prom burned for 92 z28, 406cui, tpis intake, slp runners, holley 58mm tb, dart heads, 32psi injectors, shorties w/dual 2.50" exhaust, 520/520 roller cam tpis zz409, etc........... anyway, seems to run pretty good most of the time (got 200 miles now) however, just got a code 32 after cruising at 70 for awhile on a break in run. Seems to me I told the prom guy that we were deleting the egr. Should I still be able to get a code 32 now if it was done properly? Also on the scanner I get varying egr readings. Would that be correct? the egr solenoid has been removed as well. Also, temps are a little warm yet I have a 2 row northern radiator in it. Shouldn't the prom guy have made both my fans kick on sooner as well?? My IAC doesn't seem to be reading anything and I have the throttle plate screw in all the way. Can anybody out there shed any light on these issues or am I in the wrong forum? Thanks for your time. Oh yeah, the car has died a couple of times now for no apparent reason & doesn't idle as smooth as I had anticipated with a new balanced motor.
Old Jul 30, 2009 | 12:06 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Re: help with code 32
Code 32 should not display if the PROM has the EGR turned off properly. You could get a Willem programmer, ALDL cable, and free software and tune for less than $150. It would be worth it in the long run. To get it running right usually takes anywhere between 10-1,000 chip burns.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
