engine noise
Old Jul 26, 2009 | 01:04 PM
lordmetalz28's Avatar
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
engine noise
so my iroc just started making a noise from the motor.. i dont think its rod knocking.. i have plenty of oil pressure.. when you first start the motor up it dosent make any noise at all sounds great. but let her idle for about 15 seconds and the noise magically appears... it does go with the rpm,s but if your reving it sometimes the click or knock will stop briefly and then comeback.. any ideas.. im lost
Old Jul 30, 2009 | 07:13 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: engine noise
Sounds like a problem with your lifters. Best way to confirm this is to pull the valve covers and run the motor at night with a strobe light or a timing light running. Like that it will be very easy to see odd behavior of the rocker arms weather it be one isnt opening as far as it should or the rocker is behaving oddly in general. If this is the case it will be time to take a deeper look into things.
theshackle
Sep 17, 2020 08:26 AM
B_Dubya
Aug 26, 2015 05:09 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
BlackBoulder
Aug 11, 2015 11:15 PM
