89 iroc 350 tpi hard start rough idle.. help!
Old Jul 30, 2009 | 10:37 AM
Towinainteazy's Avatar
Iam really stumped. I have a 89 iroc 350 tpi. I have to start it with starting fluid. it runs OK ( kinda on the rich side) and idle it speeds up and down (sounds like a mild cam lol) Ive replaced everything in the fuel system except the injectors. My resistance readings from front pass side are (16.0, 16.2, 16.3, 16.3) and from front driver side are (15.4, 15.9, 16.3, 16.4) these are oem as far as i'am aware of. ECM has been replaced , and has good fuel pump press to the line. Any idea's or a since of direction would be much appreciated. thanks! Towinainteazy
Old Jul 30, 2009 | 11:20 AM
knightrider64's Avatar
From: Three Rivers, Michigan. I grew up here and decide to come back here after being in the Army 7 years.
Car: Black 89 GTA Trans Am
Engine: 350 V-8
Transmission: what ever the factory put in it
Axle/Gears: not sure yet
Re: 89 iroc 350 tpi hard start rough idle.. help!
I have the 89 GTA Trans Am and it starts fine initially but runs terribly. If you shut it off right away it wont restart but does with starting fluid. Fuel pressure is good, ignition module is new, new mass air flow didnt change a thing and it has a new fuel pressure regulator on it. If the car sits for 15 minutes after being shut off will restart also without fluid. It has new wires and plugs. I was told that 6 of 8 injectors have high resistance. Should I change them or could it be the computer? I'm highly frustrated too.
Old Jul 31, 2009 | 03:49 PM
I think you might have a bad injector when they heat up.
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
gta power
Aug 13, 2015 06:15 AM
mustangman65_79
Aug 11, 2015 03:17 PM
apie2546
Aug 10, 2015 05:43 PM
