IAC Motor buzzes when trying to read codes
Old Jul 30, 2009 | 09:28 PM
fitzy's Avatar
I'm trying to sort out an intermitent code 33 problem on my 400 motor
installed in an 81 stepside 4x4
The TPI was installed using all new sensors and a Painless wiring harness.
I bought the truck with the TPI installed and it came with the code 33
issue.
Tonight while reading the codes by shorting out terminal A-B I noticed
that the IAC motor makes a buzzing sound.
Is this normal or could this be part of the problem.
Thanks, Fitzy
Old Aug 1, 2009 | 05:12 PM
fitzy's Avatar
Re: IAC Motor buzzes when trying to read codes
Can any one help with this one? Just trying to figure out if it's normal to hear the IAC Motor clicking when you short out a-b to read the codes.
Thanks, Fitzy
Old Aug 1, 2009 | 07:44 PM
NY87Iroc's Avatar
Car: 1987 Iroc convertible
Axle/Gears: 3.42 posi
Pretty sure its normal...mine does it anyway
Old Aug 2, 2009 | 04:24 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Yes it's normal
it's the way you set your min idle to
close the iac
Old Aug 2, 2009 | 07:30 PM
fitzy's Avatar
Thanks,
I'll do a search and see what info I can find on the code 33.
It looks like some others on this site have had a tough time with this code also.
specialized
Jun 18, 2022 09:26 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
