W.O.T. settings for a 383 T.P.I.
Old Aug 2, 2009 | 08:03 PM
Americanmouse's Avatar
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
Ok,
I need help with setting my T.P.S. / I.A.C.(at least this is what I'm assuming) The car runs fine idles in park at 8-900rpm and about 750rpm in gear. It cruises fine but when I go W.O.T. at either a stop or cruising, its fine up til right before it shifts gears and it bogs down/stumbles then its good til the next shift comes up and it does it again. My current T.P.S. IS AT .58, I've been screwing around with this for weeks now and I 'm not getting any where. So any ideas suggestions etc. would be great cause I'm out of ideas. I also don't know if this matters or not but its hard to start when its warm, even to the point were it won't start til it cools off.
I'm assuming because of the amount of additional cubic inches and the larger intake and fuel set up that I have I can't go with stock settings.
My stats are below!
383 L98 TPI
Stock plenum ported/simeased for the runners and throttle body
Edelbrock intake manifold and runners ported and simesed
Edelbrock Performer heads ported 64cc & 160/202 intake/exhaust
Edelbrock BBK 58mm Throttle Body
Racetronix 40lb. Injectors PRESSURE SET AT 40#
Holley adj. fuel pressure regulator
Crane 1.6 Roller Rockers
Comp cam Hydraulic roller:
510/540 gross lift 1.6 rockers bump up lift to 576
Duration at .050 intake:230/exhaust244
Lobe separation:112
MSD HEI distributor with cap & rotor
MSD Blaster coil
MSD box 6AL with rev. limiter
Hooker 2210 long tube coated headers 1 3/4
Mufflex 3.0" Exhaust System
3” Flowmaster Race Series muffler
SLP cold air induction
K/N air filter
Grantanelli adj. Mas air flow sensor
Old Aug 2, 2009 | 08:22 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Re: W.O.T. settings for a 383 T.P.I.
Yes, you can't go with the stock settings.
learn to program your own chips
on the DIY boards, read the stickies on
the DIY forum they will really help
you learn and the equipment to get you started
Old Aug 2, 2009 | 09:39 PM
MaxpowerTA's Avatar
Car: 1992 T/A convertible
Engine: LB9 TFS175heads Ebase/accel runners
Transmission: T5 5spd
Axle/Gears: 4.11
So you made all those mods and your running a stock prom?
Old Aug 3, 2009 | 09:06 AM
Car: 1988 IROC-Z28
I'm using a custom chip made by Ed Wright at Fast Chip.com
The problem is he came right out and told me he's not too familiar with TPI's, and knows more about LT1's and LS1's.
So I was hoping that some one on this board could give me ideas/advise on what I need to do.
Old Aug 3, 2009 | 08:56 PM
Car: 1988 IROC-Z28
Ok just an update!
after talking to a couple of different sources I was told I may have a bad coil (weak spark), or I'm losing fuel pressure at w.o.t. So I have a MSD Blaster Coil on order, since my last one died on me and I've been using my old stock coil. And I was told hook up my fuel pressure gauge and mount it so I can watch it and go w.o.t. and see if the gauge shows a drop in fuel pressure, which would indicate the problem.
Still open for other suggestions though!
Old Aug 6, 2009 | 09:09 AM
Car: 1988 IROC-Z28
Well I put in a MSD high performance coil and though I still need to do a test drive, the engine feels stronger and more responsive.
My question now is can the coil actually change my settings on my t.p.s./i.a.c.? Cause I was playing with it last nite, and I actually had to lower my t.p.s. setting to about .40! Is this normal? I'm going to reset everything to basic hopfully tonite and try to dial it in.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
mhatfield 14
Oct 24, 2015 07:48 AM
Mickeyruder
Sep 2, 2015 02:45 PM
LT1Formula
Aug 20, 2015 09:36 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
