Modified L98 track results, 13.68@100.6
Old Aug 2, 2009 | 11:16 PM
87350IROC's Avatar
Car: 87' IROC
I finally got around to getting the IROC to the track since building the motor 5 years ago. I ran a best of 13.68@100.6 with a 2.031 60 foot. Which is about what I expected based on how it feels on the street. However with the combination I am running I would expect it to be a fair bit faster. The car was hooking up pretty well. My setup:
1987 IROC
3450lbs without me (170lbs)
L98 block
Trickflow KD 195cc heads - straight out of the box
ZZ4 cam
Edelbrock TPI manifold
AS&M Runners
Ported Plenum
stock throttle body
24lb injectors
SLP 1-3/4" headers
Catco cat
Edelbrock 3" exhaust
700R4 trans
3.27 posi 9 bolt
completely stock suspension
245/50/16 Goodyear GS-D3 tires
car was tuned before rebuild, before heads, before cam, motor was burning oil at the time, but is setup for 24lb injectors
So what do you think?
I think I need to get the car tuned. Hopefully that will help a lot. I also wonder the condition of the cat after so much oil has been burned through it?
John
Old Aug 2, 2009 | 11:42 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
Re: Modified L98 track results, 13.68@100.6
i think you should do some suspension mods with that combo... you should be in the high to mid 12s with that setup... you have a pretty good setup there.... alot of people over look a stall converter and shift kit, that would help out greatly....a tune would also greatly benefit that setup..... alot of people need to remember that these cars are 18+ years old and they are not going to perform like they did new.....on my old setup i did full bolt ons with the highflow tpi intake similar to yours and added a crane 2032 cam and ended blowing up my 130,000 l98 engine.. got it dynoed and it only put out 213whp by 283wtq....
Old Aug 3, 2009 | 12:36 AM
87350IROC's Avatar
Car: 87' IROC
Yeah actually I'm going through the suspension this fall. Although it will not be a drag setup. I plan to replace everything. See this thread if you are interested.
https://www.thirdgen.org/forums/susp...-build-up.html
No doubt it will help though, maybe hit the tires a little harder. Doesn't explain the lack of MPH though. Motor has about 5000 miles on it. Trans has about 10000 miles on it with a trans-go shift kit. Converter is stock. I'm not sinking any more money into the trans. The car will get a T-56 within a year or so.
Agreed though, I think the car should do high 12's with everything set up right.
Old Aug 3, 2009 | 03:12 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
What was your 60ft and 1/8 mile?
Old Aug 3, 2009 | 08:16 AM
88fastgta's Avatar
well if you engine is that new and you have a shift kit i would say its all in the tune then...... my car would stall out with the hotcam and felt like a pig until i got it tuned.. now my car has loads of low and midrange rpm....
Old Aug 3, 2009 | 10:10 AM
87350IROC's Avatar
Car: 87' IROC
60 foot was 2.031 sec. Very consistent all night. I don't have the 1/8th on me right now. Will have to check when I get home.
On the positive side, I surprised a few LS1 cars by running right next to them for the first 1/8th, and beating all of them to 330'. Also beat a "560 rwhp" supercharged new mustang who was running mid 14's,
Old Aug 4, 2009 | 12:41 AM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
l98 ftw. and the camaro looks veryy sexy.
nice work!
Old Aug 4, 2009 | 01:08 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Nice running! Got a better time then me my first and only time at the track! I plan on going out again soon though...
Old Aug 4, 2009 | 02:09 AM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
If you get that 60' time down via a Tire and a converter then you will be sniffing the 12s.
Its not bad but I am positive you have a lot of room to improve.
PM me if you want to know what I did with my stock set up with mininmal work/ untouched L98.
Old Aug 5, 2009 | 01:58 AM
cronsformula350's Avatar
Car: 89 Formula L98 power
Engine: '96 subaru, opposed 4banger
Transmission: TH700R4, subaru 4WD
Axle/Gears: 3.27, just works
Check out my IROC-Z and see the times I posted with a stock motor basically, with a few mods, lol, u'll be disapointed with your car, it had 156,000 miles on in too, with a slipping trans.
Its at www.cardomain.com/ride/471099/8
Old Aug 5, 2009 | 02:52 AM
87350IROC's Avatar
Car: 87' IROC
Does anyone think the cat could be clogged up for burning a lot of oil through it?
Anything else other than just getting the thing tuned?
Thanks,
John
Old Aug 5, 2009 | 07:44 AM
88fastgta's Avatar
yea of course... my old converter got clogged because my engine was running rich and then lean...... you couldnt even see through the converter anymore.... so i gutted mine and it didnt seem to struggle nearly as hard..... if it were me i would gut mine... not that hard to do... i used a hammer and pick and then i vacummed out all the dirt and crap that fell out......
Old Aug 5, 2009 | 10:36 AM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
just leaving it gutted tends to create turbulence, causing some backpressure issues. drive a pipe through it after gutting it so that you have a clean path for the exhaust.
morrow
Members Camaros
196
Jan 13, 2024 12:21 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
ctoledo0834
Sep 18, 2015 04:16 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
