FIRST FUEL INJECTION's intake?????
Any body runnin this?? I need a new setup for an extensive engine build and would like some feed back on this setup. I like the stock appearance but don't need stock appearance just sumthing that works well. thanks
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
Re: FIRST FUEL INJECTION's intake?????
There are a few people on this board running it. Below are some links. What engine build are you planning on? If you want high HP you could look into alternate intake systems such as holley stealth ram (HSR) or TPIS minram.
Stock TPI intake was designed for 305. Chevy slapped it on the 350 since they didn't redesign a proper one. Companies (TPIS, SLP) have been selling larger intake runners and manifolds to help 350 and 383 engines breath better. FIRST injection is a properly designed TPI intake system that flows very well at 300 cfm stock. Check out their below website which shows picture comparison of stock vs FIRST intake runner diameters. This is the best aftermarket flowing TPI system stock out of the box. You can only reach these flow numbers with the TPIS or SLP after heavy porting and modifications. FIRST intake will maximize tourque over HP but will help give more of both with a built engine. Rpm band is raised some to around 5,800 but not as much as other intakes that are around 6,200-6,500. Depends what and where you want power.
Manufacturers web site http://www.firstfuelinjection.com/products.htm
Webiste for guy who installed it on 82 vette http://ncarboni.home.att.net/NCtpi.html
https://www.thirdgen.org/forums/alte...tion-guys.html
https://www.thirdgen.org/forums/alte...ction-hsr.html
https://www.thirdgen.org/forums/tpi/...st-intake.html
https://www.thirdgen.org/forums/alte...rformance.html
The hopeful end result by spring will be turning my 350 engine to a 396 with around 520hp at the fly and 530 - 540tq. The engine builder didnt say how many cfm he wanted but strongly sugested the Lingenfelter stealthram, and to stay away from the miniram and the holley system due to them not flowin enuff. So I think the FIRST seams to be what I want.
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
They are based in wisconsin and were at a show this weekend. They had cutaways of the stock unit and theirs and theirs looked very impressive.
Did you get any pix?? I know the runners are a huge improvement, but the plenum is also just as important if not more important so I would luv to see the difference in the plenums!!!
https://www.thirdgen.org/forums/alte...runners-3.html
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
