Dyno results this weekend....
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
For those of you that might have missed it...
My lateest setup was tested Satuday on the dyno.
Results are as follows:
1st pull netted 365 HP & 395 TQ
After Kevin91z did his tuning tricks the net result was 373 HP & 410 TQ.
All this with a car that passed Ca. smog w/cats in place.
See sig.
See sig.
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Dyno results this weekend....
Very good. Shows what a TPI system can do. The torque numbers are amazing for a so called "short runner" system. Don, your rear tires are going to hate you.
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
Wow, I've wanted a set of Etec 200's for a while....nice numbers! Any port work to the heads?
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
damn man how did you get those numbers.... what is the specs of your cam... with my afr 180 and 1.6 rocker swap with my current combo i hope i can achieve 330whp and 360wtq with my tpi... it must be in the tune..... when i do swap im going to need someone to personally tune my car..... i want those similar numbers....
damn man how did you get those numbers.... what is the specs of your cam... with my afr 180 and 1.6 rocker swap with my current combo i hope i can achieve 330whp and 360whp with my tpi... it must be in the tune..... when i do swap im going to need someone to personally tune my car..... i want those similar numbers....
277/286 .....225/232 @ .050 114 LSA .580 in.(1.65) .550 ex. (1.5)
The main thing is the intake, do a search for Super Vortec by Jerrywho.
And
The runners:
https://www.thirdgen.org/forums/atta...runner-mod.jpg
wow that runner is crazy.... this is mine..... how do you think i did... your cam is bigger than my gm hot cam..... i also got the edelbrock intake and slp cold air intake...
Car: '91 Camaro Z28
Car: 1989 GTA
Engine: 369 TPI
"i also got the edelbrock intake and slp cold air intake"
We had a 383 car on the dyno with the SLP cold air intake. I don't remember the exact results but the horsepower increase without the SLP intake was around 15 horsepower. You would be better off with a custom made cold air intake. My motor showed no loss of power with my CAI and the filter on.
man i used to live in victorville california..... if i was still there i would let you guys tune my car.... my tpi system may not be ported like dyno dons but its pretty hogged in the pic i showed in the eariler post.... if i had 330whp and 350wtq i would be pretty happy..... i'll probably get my car dynoed later this year just to see where its at....
LT1Formula
Oct 8, 2015 08:34 PM
