Fuel in Plenum
Old Aug 15, 2009 | 04:16 PM
Clutch_Grabwell's Avatar
Car: 1986 Monte Carlo SS
Engine: 1989 L98
Axle/Gears: 8.5" 3.42:1 posi
Fuel in Plenum
I've got a theory and would like to see if anyone agrees...
My motor ('89 L98 in a Monte) suddenly became hard to start and unwilling to idle after being driven for a while. No codes but the exhaust smelled rich. A local shop took a look and told me that the fuel pressure was dropping quickly even with both fuel lines pinched shut.
The injectors were the prime suspect but they've only got a few thousand miles on them. I removed the upper intake this morning and found a snootful of fuel in there.
The new suspect is the fuel pressure regulator diaphragm. Any thoughts?
Old Aug 15, 2009 | 05:19 PM
F-Body Demon's Avatar
Re: Fuel in Plenum
Sounds right to me.
Old Aug 15, 2009 | 05:24 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: Fuel in Plenum
well, if you pinched BOTH fuel lines, you wouldn't get ANY fuel (fuel pressure) to the rails/injectors. But yes, fuel in the plenum is a ruptured diaphragm. Take the plenum off and the fuel pressure regulator and replace the diaphragm...Replace this. (click on pic)
Old Aug 15, 2009 | 05:27 PM
Re: Fuel in Plenum
You can test it by pulling the vacuum line to the AFPR. If fuel pours out you have your answer.
Old Aug 15, 2009 | 05:56 PM
chads89ta's Avatar
Car: red 89 t-top ta
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 9 bolt soon
Re: Fuel in Plenum
yep, your regulator is bad
Old Aug 15, 2009 | 06:06 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Re: Fuel in Plenum
Bump... Post up your findings on this as I had the same thing happen to me yesterday, and had not considered my AFPR as a possible culprit. My L98 TPI 350 started fighting me on startup whereas it was fine 2 days earlier.
Old Aug 15, 2009 | 07:08 PM
Engine: 1989 L98
Re: Fuel in Plenum
Originally Posted by omnipotentgoku
Bump... Post up your findings on this as I had the same thing happen to me yesterday...
Thanks to everyone for the confirmation.
F-Body Demon was right on the money. Gas is coming out of the regulator's vacuum port. omnipotentgoku; it's time to get to work!
Old Aug 16, 2009 | 01:28 AM
Car: 1987 IROC Z
Re: Fuel in Plenum
Crazy.. do I pull that line while the ignition is off?
Old Aug 16, 2009 | 01:45 AM
HCR13's Avatar
Car: 1987 Trans Am
Re: Fuel in Plenum
no, just start your car like normal (if it'll idle) and then unplug the vacuum line to the pressure regulator, if gas squirts out, your diaphragm is ruptured...
Old Aug 16, 2009 | 04:32 AM
3rdgenred's Avatar
Car: 6.7 Powerstroke
Re: Fuel in Plenum
Its your fuel pressure regulator man, Follow my thread about my fuel pressure regulator here man :> https://www.thirdgen.org/forums/tpi/...lace-fuel.html
Old Aug 20, 2009 | 10:28 PM
Car: 1987 IROC Z
Re: Fuel in Plenum
crap.... no dice brothers... I pulled the vacuum line from the plenum to see if it would leak while it was idling, but it didnt! now im really confused and not sure what to try. The biggest symptom is my car is blowing off excessive white smoke when starting the car, and its still fighting me to start as though it was carb'd.
This started happening when I was looking into a problem with my fan (set to always run) stopped running. I thought it might have been a relay of some sort but did not know which was the fan relay. I also changed out all of my fuses (because I found some fuses that were incorrect amp) as a possibility, but no dice.
Ah.. I just read the post... would it make a difference that I unplugged the end of the line on the plenum rather than the end of the line on the FPR?
Old Aug 21, 2009 | 07:18 AM
PV9685's Avatar
Car: 89 Firebird Formula
Engine: 305 Vortec, Single-plane, 4 barrel
Transmission: T5, soon 700R4
Axle/Gears: 88 10 Bolt, Disc, Auburn, 3.23
Re: Fuel in Plenum
You would be better off to pull the end on the FPR - at least it won't need to fill the tube before a leak may be observed. I read recently that if you smell a heavy odor of fuel in the tube that you may have a leak; mine smells heavily of fuel but no visible leak - perhaps it's a small leak/perhaps it's just old and crusty and everything stinks like gas (hey, it's a V8).
...Worst case scenario..Perhaps you have an exhaust valve that is no longer opening? If you don't want to get to deep, disable the injectors 1-by-1.
Old Sep 10, 2009 | 06:20 PM
Car: 1987 IROC Z
Re: Fuel in Plenum
Well I ended up changing the diaphragm, but this didn't help really. The one in their was not ripped... So I still am like ???
New line of thought...
The cold start injector. I am pretty sure I had this disabled in the prom when i had it burned. Could this be a source of fuel ?
Old Sep 10, 2009 | 08:09 PM
HCR13's Avatar
Car: 1987 Trans Am
Re: Fuel in Plenum
well if its disabled, then just get a block-off kit for the cold start and be done with it...
MantyZ28
16
Dec 21, 2015 11:02 AM
Hawkeye1980
Aug 31, 2015 07:09 AM
TheExaminer
Aug 26, 2015 04:59 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
355tpipickup
Aug 22, 2015 06:06 PM
